Local Time 05:34 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Reading a pixel colour
Henk
Posted: 01:04am 04 Feb 2017
I am using a explorer 100 with attached lcd display. I am looking for a way to read the colour a pixel is set. I thought I remembered that you could read the pixel colour in the past but I cannot find it in the manual. Is there a way or do I remember it wrong?
Posted: 01:14am 04 Feb 2017
You need to make sure the RD pin to the display is connected and configured using
OPTION LCDPANEL SSD1963_x,L,,RDpinNo
Then just use col=PIXEL(x,y)
Henk
Posted: 01:40am 04 Feb 2017
Thank's i am going to try it.
Henk
Posted: 01:53am 04 Feb 2017
Seems it doesn't work. ERROR:PIXEL not declared. It things its a function. Also tried without brackets but another error shows up.
Posted: 01:57am 04 Feb 2017
Are you running 5.3? It only appeared in that release
Henk
Posted: 01:59am 04 Feb 2017
Oke i am using 5.2 so I first have to upgrade. thanks.
Henk
Posted: 01:44am 05 Feb 2017
Next problem I try to program the explore 100 with the new firmware but MPLAB (latest version just downloaded) does not show the PIC32MX470 it goes to 460 and so it will not program the chip with my Pickit 3. How to program it with the new firmware?
Thanks.
Posted: 01:49am 05 Feb 2017
You need the MPLabX IPE
Henk
Posted: 02:19am 05 Feb 2017
Thanks I just discovered this. I have 3 icons on the desktop for Mplab and did not try this one. All very confusing this MPlab software.
