Local Time 05:28 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMEdit saving - when done....
Posted: 02:17pm 30 Jan 2017
Hi all.
When you save code you are writing in MMEdit, is there any way to STOP MMEdit from automatically homing the cursor to line 1 when it does this?
While it is not THAT much of a problem to scroll down to where you were before, when your code is 1000+ lines, it is a pain in the bum to have to do that every time you save the update.
I had a look in settings/preferences, but could not see anything to let me do that.
Jim?
Posted: 03:16pm 30 Jan 2017
Gee, you want everything...
Here's one I prepared earlier..
2017-01-31_010854_MMedit.zip
The resetting the cursor was annoying me too so I fixed it last week.
'save' and 'format' now remember the cursor line (but not the position on the line).
The line might end up in a different position on the screen but it should be visible.
There might be a few other places where it resets and I will fix that too when I discover them.
Retaining the cursor line when you do a 'crunch' is a bit trickier but it is something I will have a play with.
The other changes are a couple of new macro commands to insert the current date and time into the macro string.
I have also improved the VT colour handling.
I will put out a proper update once V5.3 is finalised and I have done the syntax files.
Posted: 04:15pm 30 Jan 2017
Sorry if I am being a pain. NOT criticizing your efforts, it was just a question.
Thanks though.
Posted: 05:24pm 30 Jan 2017
  Grogster said   Sorry if I am being a pain. NOT criticizing your efforts, it was just a question.
Not a pain at all.
I really did do the changes a week ago.
