Local Time 05:28 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : DATA
palcal
Posted: 03:48pm 27 Jan 2017
I am writing some code and would find it very useful if I could access two different lots of data. At the moment I have to read through 400 odd entries as junk before I get to the second lot of data. Then RESTORE to go back.
Maybe DATA1 and READ1. DATA2 and READ2 etc.
OR is there already an easy way to do this.
Paul.
paceman
Posted: 04:23pm 27 Jan 2017
Paul, if you're using a Micromite+ then the easy way might be to read and write to the SD card, depending how fast and often you need to do it. That way you can use the random SEEK command to take you direct to the data you want and you also can have five files open at once. Its in the Micromite Plus Manual.
Greg
Posted: 04:44pm 27 Jan 2017
RESTORE lets you RESTORE to a specific line number (or label)
That will get you to a known place in each group of data.
palcal
Posted: 05:41pm 27 Jan 2017
Thanks Greg and Jim.
Paul
