Local Time 05:28 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : mm+64 and ssd1963
plasma
Posted: 05:52am 25 Jan 2017
Hi ,
my 7" Display come this morning (SSD1963) , i will use it with the latest MZ based Micromite .
But my latest Hardware is a mm+64 so i need a test with this . the seller wrote the display has 16 bit interface , what should i do? will the standard 1963 driver run (8 bit) ?
thxEdited by plasma 2017-01-26
Posted: 05:53am 25 Jan 2017
  Quote  will the standard 1963 driver run (8 bit) ?
Yes. There is no difference to the connections for the lower 8 bits and the control signals
plasma
Posted: 06:03am 25 Jan 2017
thx matherp,
what about the last 8 bit ? will the driver automatically changed or do i need a bridge on the display to change between 8/16 bit mode
Posted: 06:47am 25 Jan 2017
No change needed. The SSD1963 isn't really true 16-bit. All the commands and cursor positioning are done in 8 bits even though setting the x and y coordinates then need two bytes sending. It is only the colour which uses the extra bits and that is just set up in the initialisation commands in the software
plasma
Posted: 08:37am 25 Jan 2017
it works !
thx matherp
