Forum Index : Microcontroller and PC projects : MM ANALOG POWER pins & additional serial
| lizby Guru Joined: 17/05/2016 Location: United StatesPosts: 3881 |
On the 28-pin micromite, can the Analog Power and Analog Ground pins be reconfigured as serial (or digital) pins if analog is not needed? In the manual, in Appendix A, Serial Communications, it says: "Additional serial ports can be added to the Micromite by using the SerialTx and SerialRx embedded C modules. These are included in the "Embedded C Modules" folder in the Micromite firmware zip file." Is the means of doing this explained in the referenced firmware zip file or somewhere else? PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6608 |
No they are power pins and cannot be reconfigured. Information on how to use the C functions is covered in the Embedded C Modules folder of the firmware ZIP file Jim VK7JH MMedit |
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10048 |
Hi. ![]() Refer to the attached PDF files. They are included as part of the Micromite firmware download ZIP file, but you might not have downloaded that. Serial transmitter for any I/O pin Serial receiver for any I/O pin The instructions are all in the PDF, and you just copy the C-Function text into your program, and when you run it, you will magically have as many serial port pins as you want. ![]() Smoke makes things work. When the smoke gets out, it stops! |
