Local Time 16:00 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : GUI DROPDOWN?????
Posted: 09:03pm 12 Jan 2017
Are there any plans to have a dropdown box GUI control sometime in the future?
They work the same way as any other GUI control, but there is a list of options you can choose one from - I am sure 99% of you know what a dropdown box is......
You could store the data to show in the list in a simple one-dimensional array, so that pseudo-code would be like:
GUI DROPDOWN #1,LST$(),StartX,StartY,ListSize,Justify,Fcolour,Bcolour
....with ListSize being the size of the dropdown box when selected, NOT the number of items contained in the list.
You could define what you wanted the list to have in it with the likes of DIM LST$(10) LENGTH 15 kind of idea, and store the items for the dropdown list within that simple array: LST$(1)="Option 1":LST$(2)="Line 2":LST$(3)="Line 3" - that kind of idea or similar.
A dropdown box or scrolling box is about the only GUI control missing at the moment.
This may well be much more difficult then I think it is, to code, animate and to have MMBASIC manage in the background, compared to the existing controls.
Thoughts?
Comments?Edited by Grogster 2017-01-14
RonnS
Posted: 09:32pm 12 Jan 2017
hi,
this would be my favorite too, it should remind me of the old "Amiga" times: on Menu goto lol
but take a look a this
http://www.thebackshed.com/forum/forum_posts.asp?TID=7819&KW=Ronns
Ron
Posted: 09:49pm 12 Jan 2017
This is a great idea but I can see people wanting more and more features with the drop-down (which possibly need to be considered when designing such a GUI control)
For example;
- Which element to show initially in the 'unselected' dropdown text area (maybe specify as 'x' in the LST$(x) pointer)
- Pixel width (dangerous to auto create depending on maximum data length in LST$())
- Foreground/background colours to highlight current selection when dropdown shows (could simply be the colours inverted)
- Font size (may need to be different from current font - possibly FONT prior to GUI DROPDOWN)
I am NOT saying these have to be in - just that it needs to be a well defined syntax to begin with; hence some ideas included above).
Also, what about numeric as opposed to string - so LST$(x) is simply LST(X) if numeric.
This has very much got my vote too - not time to rest just yet Peter!
Posted: 11:49pm 12 Jan 2017
I was thinking that the list to show via the control, could be anything - including numbers(stored as ASCII) if that was what you wanted. Easy to convert them into "Real" numbers with something like NUM=VAL(CTRLVAL(DROPDOWN)) kind of thing, and if you want ASCII, just read the control directly.
I am just throwing the idea about - certainly not lamenting it not being there or anything, but now with talk of MOUSE CONTROL being a possibility in the near future, dropdown boxes could be really useful.
Thinking about this a little more, you would drop the ListSize part of the control.
It would be easiest to just have the list drop down the same number of lines to choose from - that's what even modern ones do, so......
Posted: 02:49am 13 Jan 2017
Yes, a dropdown box (and a circular gauge) must be part of the core group of controls. Both have been on my wish list for some time but there have been lots of distractions (many worthwhile) - the whole Micromite world has been growing and consuming time.
Grogs, your outline sounds very much like the perfect spec. It is on the "features to implement" list.
Posted: 01:36pm 13 Jan 2017
Owwwwwww - awesome.
Posted: 09:24am 23 Aug 2020
Came across this thread tonight while searching for something else.
Did this ever get implemented?
Posted: 12:27pm 23 Aug 2020
No, sorry.  I tried but I could not get a dropdown list to work in a reliable way.  It needed too many graphical elements (such as a scrolling list) that were next to impossible to operate with a blunt finger.
Posted: 01:49am 25 Aug 2020
OK. Thanks.
I won't plan on using that in the future then.
