Local Time 07:11 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : If you HAVE to mix GUI and standard....
Posted: 04:56pm 27 Dec 2016
Hi folks.
The next part of the code I am writing, is to have a menu where you can enter in the name of a logfile, and it will read it and show it on the screen.
LINE INPUT is made for this task, but that would mean standard TEXT commands for showing the lines from the logfile on the LCD, and two GUI buttons for page control(MORE and EXIT).
The TEXT commands and GUI controls would NOT overlap on the screen, but I don't have enough GUI elements left to make up a whole screen list full of CAPTION commands to list the logfile details, so am planning to use TEXT instead.
Just how much of a no-no is this in the grand scheme of things?
If version 5.3 of the MM+ firmware will have more GUI elements available, then I could still code for this now ahead of time - which would be the preferred way to deal with it - but how far off is the release of 5.3 does anyone know?
Posted: 10:18pm 27 Dec 2016
  Quote  Just how much of a no-no is this in the grand scheme of things?
I haven't found mixing a major issue. The only thing needed is to have a redraw function for the non-GUI elements that is called when you get the penup interrupt from text and number boxes or if needed on page changes. Note there is a bug in penup on 5.2 but this is fixed in the 5.3 beta released by GeoffEdited by matherp 2016-12-29
Posted: 12:32am 28 Dec 2016
OK, cool, thanks.
I will proceed along the lines of text and a couple of GUI buttons for these screens only then.
Phil23
Posted: 12:39pm 21 May 2017
Just back on this, the element mixing.
While I'd had no issues with my Tabbed Screens I did discover another trap.
That code was running unchanged, unfinished on both 5.2 & 5.3 for ages.
No display issues or corruption. Just worked fine.
Then I broke it a bit.
I decided I'd make the GUI LED's blink on coms rather than just toggle state.
When I made the LED flash under the GUI, I started getting a bit of text corruption around them.
Basically I think the GUI was sometimes repositioning the cursor co-ordinates mid way thru writing a TEXT string on odd occasions when the LED turned off.
Returned them to the toggling code & it was fine again.
Phil.
