Local Time 05:08 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : GUI Line?
Posted: 05:49pm 20 Dec 2016
Hi.
I often want to underline text in a menu on an GUI page.
At the moment, I am just using the LINE command to directly draw the line, but with GUI programming, EVERYTHING is supposed to be a declared GUI element - such as using GUI CAPTION for text.
Is this likely to cause problems later?
Is there any way to correctly deal with underlining captions in a GUI?
Could this be added by way of a Cfunction or other?
I guess I could use an underline font, but the underline is a different colour to that of the caption text it is under, so that won't really be idea either.
Any suggestions or input at this point would be great, as I don't REALLY want to use any standard drawing commands when setting up my GUI pages, as that is considered a no-no, but I still want my underlining..........
disco4now
Posted: 07:40pm 20 Dec 2016
I have not tried it, but will GUI Display Box accept a height of 1 or 2. to give you a line.
From the manual:
Display Box
GUI DISPLAYBOX #ref, StartX, StartY, Width, Height, FColour, BColour
This will draw a box with rounded corners. Any text can be displayed in the box by using the CtrlVal(r) =
command. This is useful for displaying text, numbers and messages. This control does not respond to touch.
F4 H7FotSF4xGT
Posted: 08:01pm 20 Dec 2016
Worth a try - I will look into it.
EDIT: Nope. Invalid. Minimum is 16, which is way too big. If anyone else has any ideas here....
At the end of the day, I can - and will - just put the main menu title inside a display box and deal with it that way. There will be no underlining in that case, but I would rather play by the GUI rules then end up with a mixture of GUI and standard drawing commands which might cause problems later.
So, this is a low-priority thread in other words.....Edited by Grogster 2016-12-22
disco4now
Posted: 08:36pm 20 Dec 2016
What about a 17 high display box in the background colour over the top of the 16 high display box, just leaving the bottom line not overwritten.
F4 H7FotSF4xGT
Posted: 09:05pm 20 Dec 2016
This is something missing in the MM+. There needs to be some way to draw lines, etc under GUI control so that they are dimmed when a number/text box pops up.
On my todo list.
Phil23
Posted: 10:36am 22 Dec 2016
Hi Grog,
Have you tried mixing Basic & advanced graphics?
I know it's not recommended, but I've played with it a bit with good results.
Just needed to have a few checks in place, to trap for the conflicts.
From memory, CLS & GUI Show All & some basic graphics refreshes.
There's some of the code in this post.
Phil.
palcal
Posted: 10:59am 22 Dec 2016
Grogs,
Haven't tried this but could you use font tweak to make the underlined characters you need.
Paul.
Posted: 02:28pm 22 Dec 2016
Hi there.
@ Phil23 - YES, that DOES work, but I am loathe to use it, as generally speaking, it is a no-no to mix GUI elements and standard graphics elements if you want a trouble-free GUI experience. I know that this can and does cause LOTS of issues, as my first experiments did exactly that, and the GUI would get corrupted and all sorts of horrible things went on, so this time around, I have learned from that mistake, and am coding the GUI system in entirely GUI controlled elements - no mix and match.
I am happy enough with DISPLAYBOX. It does the job, and a displaybox around the main menu at the top looks better then a simple underline once you look at it more then once or twice.
@ Paul - Yeah, I thought of using an underline font at one point too, but now that I have decided to go with the displaybox concept, I'm happy enough.
isochronic
Posted: 11:04am 23 Dec 2016
Just a thought,
GUI's usually have a convention where the screen elements (active controls) are
dimmed if deactivated (not applicable), normal if applicable, and enhanced when they are the focus point. Menus, and menu items, as well..a lot of work to implement but worth it.
Underlining doesn't seem to be used much, the early web used it for hypertext instead, so maybe that was the issue
