Local Time 04:54 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PEEK and POKE
panky
Posted: 12:45pm 13 Dec 2016
For Geoff perhaps?
It has been mentioned that extreme care should be used when using the PEEK and POKE commands as this can cause a machine exception in certaion cases and corrupt the interpretter.
Is this the case for PEEK if an unused or unreachable memory location is addressed? I would like to modify my HEXDUMP program to print out memory locations but am wary of doing so if it could corrupt the interpretter.
Note, I can understand POKE being problematic and plan to stay well clear of that little monkey
Cheers, Doug.
Posted: 01:39pm 13 Dec 2016
No. Peek reads memory and doesn't change its contents. Poke has the potential to break things because it can change the instruction that is executed at a given address or some other crutial value like pointers or structures etc.
There may be restrictions on where you can peek but that would cause program errors (which you could handle in your code) and not brick your 'mite
hthEdited by CaptainBoing 2016-12-14
panky
Posted: 02:05pm 13 Dec 2016
@CaptainBoing,
Thanks mate, that is what I assumed but just wanted to check with someone.
Cheers,
Doug.
Posted: 06:39pm 13 Dec 2016
In earlier versions of MMBasic PEEKing at an invalid address would cause an exception and reboot the Micromite. The current versions (5.2 and later) check that the address is valid and will throw a standard error if invalid (you can trap this with ON ERROR).
The same address checking applies to POKE. In either case you cannot damage the Micromite or corrupt MMBasic, the worst that can happen is that you might trigger an exception and experience an involuntary reboot.
panky
Posted: 08:26pm 13 Dec 2016
Thanks Geoff.
Doug.
f1fco
Posted: 11:30pm 13 Dec 2016
Hi Geoff and the list,
is it a "special" POKE (adress and value) to voluntarily rebbot the chip ?
thanks for answer
Pierre.
73s de F1FCO
Posted: 11:42pm 13 Dec 2016
Commands.
CPU RESTART - Page 54 of standard manual.
WATCHDOG 1 - Page 72 of standard manual.
Watchdog 1 will cause the CPU to restart 1ms later.
f1fco
Posted: 12:10am 14 Dec 2016
sorry for the question !
I have forget to read attentively the manual
CPU RESTARST is exactly what I need
thank you Grogster
Pierre.
73s de F1FCO
Posted: 12:19am 14 Dec 2016
You are most welcome.
Cordialement.
