Local Time 04:54 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : jaycar 240x320 lcd controller ?
isochronic
Posted: 07:10pm 11 Dec 2016
Jaycar is flogging a small LCD arduino-style, 240x320,
8bit parallel. But I can't see what controller chip it
uses, any one with more info ?
Lightrock
Posted: 01:36am 13 Dec 2016
The Jaycar website has software and data sheets available to download under the Downloads tab on their XC4360 LCD page. A quick look at the data sheet indicates that the LCD is a 16 bit data type rather than SPI.
isochronic
Posted: 02:16pm 13 Dec 2016
[It is XC4630]
The pinout gives 8 data pins in parallel + some control pins, says the
controller chip supports scrolling, but not a lot else
edit - ie not much further info.
I am guessing it is a generic ILI9341 which would be good Edited by chronic 2016-12-15
Posted: 11:51pm 13 Dec 2016
The display is ILI9341 parallel - I don't have a current driver for this and at that price it isn't competitive with the 4.3" SSD1963 which is fully supported by the MM+
disco4now
Posted: 01:27pm 14 Dec 2016
See the post below for a loadable ILI9341 parallel driver based on Peter's previous code.
ILI9341 parrallel driver
F4 H7FotSF4xGT
isochronic
Posted: 10:46am 15 Dec 2016
Thanks, that keeps a few options open
