Local Time 04:42 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite EXTREME b3b4: 16-bit displays
Posted: 07:31am 28 Nov 2016
This release implements the new pinout for the 100-pin MZ and also includes 16-bit versions for all the variants of the SSD1963 displays. To use the 16-bit driver just add "_16" to the display type in the OPTION command as per the screen shot. The 16-bit drivers are not available on the 64-pin parts.
The advantage is the driver is MUCH faster. The disadvantage is that it uses more pins and is RGB565 rather than RGB888. The display pins DB8-DB15 are connected to pins B8-B15 in the list below.
There is no change to the pinout of the 64-pin MZ other than pin 38 being excluded from general use as it is dedicated to USB.
The pinout of the 100-pin part is the same as posted here with the exception that RX and TX have been reversed on COM3 as per Chronic's request.
Subject to any bug fixes this completes the port of MMBasic 5.3b3 and includes the key functionality I wanted to achieve to allow operation at much higher speed (CPU and display) and greater accuracy (double precision floating point). I'm open to suggestions for enhancements but these should be things that specifically take advantage of the high performance platform rather than things which Geoff may or may not choose to include in the MX470. In general my intent is that the code will stay completely compatible with the MX470. i.e. anything which runs on the MX470 will also run on the MZ with no changes (other than pin allocations).
The above test was run on a Snadpic MZ board but note the Snadpic regulators are not capable of powering a 5" or 7" display properly so I'm using an external 3.3V supply connected direct to the display with a common ground.
The command to use the Snadpic on-board SDcard is:
OPTION SDCARD 4,81,59
as it is connected to SPI channel 4 and uses 81 for CS and 59 for CD
2016-11-28_172718_MicromiteExtremeb3b4-12MHz.zip
2016-11-28_172738_MicromiteExtremeb3b4-24MHz.zip
1 G15 Analog
2 A5 Analog
3 E5 Analog
4 E6 Analog
5 E7 Analog
6 C1 Analog COUNT
7 C2 Analog COUNT
8 C3 Analog COUNT
9 C4 Analog COUNT/IR
10 G6 Analog SPI2-CLK
11 G7 Analog I2C-SDA
12 G8 Analog I2C-CLK
13 VSS
14 VDD
15 MCLR
16 G9 Analog PWM1C
17 A0 Analog
18 E8 Analog
19 E9 Analog
20 B5 Analog SSD1963-D5
21 B4 Analog SSD1963-D4
22 B3 Analog SSD1963-D3
23 B2 Analog SSD1963-D2
24 B1 Analog SSD1963-D1
25 B0 Analog SSD1963-D0
26 B6 Analog SSD1963-D6
27 B7 Analog SSD1963-D7
28 A9 Analog
29 A10 Analog
30 AVDD
31 AVSS
32 B8 Analog B8
33 B9 Analog B9
34 B10 B10
35 B11 Analog B11
36 VSS
37 VDD
38 A1 Analog
39 F13 Analog COM1-EN/SPI3-CLK
40 F12 Analog PWM2B
41 B12 Analog B12
42 B13 Analog B13
43 B14 Analog B14
44 B15 Analog B15
45 VSS
46 VDD
47 D14 Analog COM1-RX
48 D15 Analog COM1-TX
49 Oscillator
50 C15
51 VBUS
52 VDD
53 VSS
54 D-
55 D+
56 F3 USBID
57 F2 COM3-TX
58 F8 COM3-RX
59 A2 Snadpic-SD-CD
60 A3
61 A4
62 VDD
63 VSS
64 F4 SPI3-IN
65 F5 SPI3-OUT
66 A14 SPI2-OUT
67 A15 SPI4-OUT
68 D9
69 D10 SPI4-CLK
70 D11 SPI4-IN
71 D0 PWM1B
72 C13 SPI2-IN
73 C14 PWM1A
74 VDD
75 VSS
76 D1 SPI-CLK
77 D2 SPI-IN
78 D3 SPI-OUT
79 D12
80 D13
81 D4 Snadpic-SD-CS
82 D5 PWM2A
83 VDD
84 VSS
85 F0 COM4-TX
86 F1 COM4-RX
87 G1 COM2-TX
88 G0 COM2-RX
89 A6 KBD-CLK
90 A7 KBD-DAT
91 E0
92 VSS
93 VDD
94 E1
95 G14 SSD1963-RESET
96 G12 SSD1963-RS
97 G13 SSD1963-WR
98 E2
99 E3
100 E4 Analog
Edited by matherp 2016-11-29
f1fco
Posted: 08:24am 28 Nov 2016
thank you Peter !
what a fine work !!!
is it a color VGA output in your mind ?
another question, more realist :
what pin for console rx and tx ?
Pierre.
73s de F1FCO
Posted: 08:26am 28 Nov 2016
  Quote  what pin for console rx and tx ?
Console is the same as COM4, same concept as the MX470
f1fco
Posted: 08:27am 28 Nov 2016
sorry !
console is same pin as COM4 : tx on pin 85 and rx on pin 86
Pierre.
73s de F1FCO
Posted: 11:20am 28 Nov 2016
Peter,
Just out of interest, kiiid's Grain Benchmark has dropped from 4242 to 4138 with this latest release.
Is that something you would have expected?
I can assure you everything else is exactly the same:
OPTION BAUDRATE 115200
OPTION SDCARD 2,12
OPTION DISPLAY 30,100
Using console pins (i.e. not USB D+/D-)
EDIT: Should mention that this is on the 64 pin MZ on kiiid's PCB (12MHZ version)Edited by WhiteWizzard 2016-11-29
Posted: 11:39am 28 Nov 2016
  Quote  has dropped from 4242 to 4138
I think you are over analysing, it could be just tiny changes in the way the compiler optimises with small code changes
On the 200MHz Snadpic (24MHz) crystal it seems to have got faster with the same release - I'm now getting 4350
Posted: 05:06pm 28 Nov 2016
Why not use the build in PMP or EBI device to connect to a LCD.
Both support 8 bit and 16 bit.
These peripherals are specifically made to support parallel connections like an LCD.
They also support DMA which could even increase the speed more.
Posted: 08:09pm 28 Nov 2016
Awesome.
Nice work, Peter.
Would be interested to here the reply to MicroBlock's question above, but I expect there is probably a reason......
Posted: 10:13pm 28 Nov 2016
  Quote  Would be interested to here the reply to MicroBlock's question above,
It would require a complete re-write and another different pinout
It needs the image data to be prepared as a block of memory rather than created on the fly
It wouldn't be much faster, if at all, the current code already operates at peripheral bus speed for block writes and because the data doesn't need to be pre-prepared there are savings in preparation time.
Note that CLS is currently writing at 48,000,000 bytes per second including the Basic interpreter overhead!
MicroBlocks' approach is ideal IFF you have a complete framebuffer in processor accessible memory. Then the write in the program is to the frame buffer and the DMA can send that to the display in the background.
Even with the MZ we don't have enough on-chip memory for a complete framebuffer. To do this "properly" you would have external memory on the EBI for use as a framebuffer and DMA that direct to the screen via PMP. Easy enough to do but no longer a single chip solution and you really need the 144-pin chip to get enough pins.
Posted: 10:38pm 28 Nov 2016
Sure the most complicated use is with a frame buffer, this would require an LCD in RGB mode.
A much easier way to use it is to use it as a peripheral that outputs data AND controls signals like RD/WR, EN, A0/A1.
PMP is even used with graphical 2/4 line displays.
Outputting data to an LCD in parallel mode is the same.
Just put PMP in 8-bit or 16-bit mode and write/read the data.
It is just like writing/reading from PORTB.
A 'complete re-write' would be minimal as the only change is to use the PMP peripheral instead of PORTB.
The thing is, when using the PMP peripheral to connect an LCD you open up the road for more sophisticated use of the LCD. Drawing a line for instance can be optimized, even small images(sprites) could be written to the display as sequence of data without the need to wait for it to complete. Lots of other possibilities are opened up, even small video sequences.
When using the PMP in its simplest form it is just as easy to use as a PORT. The difference is that the PMP pins are then reserved for LCD use and without change in the hardware it can be used to control LCD's in very efficient ways.
As this is now in the development stage and pins are reserved for functionality i think it is the best time to consider it, as in the future it will be much harder to change and all hardware that has been developed in the meantime can not be easily used when PMP is desired.
Also as PMP has an address bus it would be possible to attach multiple LCD's enabling a whole new range of projects.
Edited by MicroBlocks 2016-11-30
Posted: 01:08am 29 Nov 2016
  Quote  he difference is that the PMP pins are then reserved for LCD use and without change in the hardware it can be used to control LCD's in very efficient ways.
PMP uses many of the PPS pins which would not leave enough on a 100-pin chip for all the other functions
  Quote  Drawing a line for instance can be optimized,
No it can't. The existing code already optimises this to the maximum extent possible:
Set the screen area, load the colour, toggle WR until the area is filled. PMP would be slower as it can't know that it doesn't need to load the colour register for each pixel.
If you want to convert the code I'm happy to send you the project to work with.
Edited by matherp 2016-11-30
Posted: 03:53am 29 Nov 2016
Researching this some time ago i had this conclusion:
PMP uses 5 relocatable pins when used in 8 bit mode and 12 when in 16 bit mode.
Using PORTB uses 7 relocatable pins when used in 8 bit mode and 13 in 16 bit mode. Using PORTB in 16 bit mode also prevents the SPI3 peripheral as the SCK3 on pin 43 is not relocatable.
I would be happy to take a look, but unfortunately time does not permit to do much work on it at the moment. October - May is the busiest time for me.
isochronic
Posted: 04:18am 29 Nov 2016
The DA will be released soon - no doubt with whiz-bang graphics -
maybe best to see what that brings or chops out
boss
Posted: 02:59pm 29 Nov 2016
144pin MZ Snadpic board
As I chatted yesterday with Mounir Dlima we should have the opportunity (hopefully in near future) to order even 144pin version of Snadpic MZ board
Bo
