Local Time 04:42 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Array create and erase
panky
Posted: 04:57pm 16 Nov 2016
Hi Folks,
Can anyone offer some advise re the following. I want to create an array, erase it then re-create it with the same name. I can't see any restrictions on this in the manual (but am happy to be told 'not possible').
The test code is
' Test program to create an a string array, erase it and
' then reuse it using the same name
Dim a_array_ptr% 'integer for pointer to array
Dim a_array$(1,1) length 1 ' 2 by 2 one char string array
a_array$(0,0)="A" 'set value into array
Print a_array$(0,0) ' print it out
a_array_ptr% = Peek(VARADDR a_array$()) 'get pointer to array
Print a_array_ptr% 'print it out
Erase a_array$ ' erase the array to free memory
on error skip
a_array_ptr%=Peek(VARADDR b_array$()) ' get pointer to array
if MM.ERRORNO <> 0 then goto exitdoor
' ** the peek should fail as array does not exist
on error skip
a_array_ptr%=Peek(VARADDR a_array$()) ' get pointer to array
' ** the peek should fail also as array was erased ???
Print a_array_ptr% 'print out pointer
Dim a_array$(2,2) length 1 ' re dim array should work ???
' ** this should work as a_array$ was erased and should now
' be available for re-use ??
a_array$(0,0) = "Z" 'assign new value
Print a_array$(0,0) ' and print
error "Not really an error - correct end of program"
exitdoor:
error "Really - an error happend up above!"
The error I get running this code under MMBasic 5.2 on a 64 pin 470 is
>run
A
2684479224
1700012071
[22] Dim a_array$(2,2) length 1 ' re dim array should work ???
Error: Array dimensions
Should PEEK to a non-existing variable throw some sort of error?
Should re-DIMing an array variable work after an ERASE if using the same array name?
Thanks,
Doug.
PS. I had hoped to include this functionality into some string/character manipulation routines I am working on.
panky
Posted: 09:16pm 27 Nov 2016
Read the manual and can not see what I am doing wrong?
Updated the code to be a little more descriptive - don't want to call this a bug but if I do something wrong program wise, shouldn't an error be created?
Dim a_array_ptr% = 0 'integer for pointer to array
Dim b_array_ptr% = 0 'integer for pointer to array which doesn't exist
Print "This is what we put in the first position of the array ",a_array$(0,0)
Print "Address of array is ",hex$(a_array_ptr%)
on error skip 'if error in next line, jump over IF ... GOTO
' ** the peek above should fail as array was erased ???
' so we should have jumped to the exitdoor
Print "Address of erased array is ",hex$(a_array_ptr%)
' Now test a non existant array
b_array_ptr%=Peek(VARADDR b_array$()) ' get pointer to array
Print "Address of non-existant array !!! ",hex$(b_array_ptr%)
' We should not get here as both Peeks above should have failed
Print "Why am I here?"
exitdoor:
