Local Time 04:26 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Bug in 5.2 string handling
Posted: 03:23am 07 Nov 2016
I've separately copied this to Geoff but be aware passing a composite string to a function where the composite includes the return from a string function will fail
option autorun on
Option explicit
option default NONE
dim s1$="start-"
dim s2$="-end"
dim integer maxtemp=144
dim b$,t$
b$=s1$+outtemp$(maxtemp)+s2$
print b$
sendtext b$ 'this works OK
t$=outtemp$(maxtemp)
sendtext s1$+t$+s2$ 'this works OK
sendText s1$+outtemp$(maxtemp)+s2$ 'this fails
function outtemp$(t as integer)
outtemp$=str$(t)
end function
sub SendText(a$)
local c$
c$=STR$(len(a$))
print c$
end sub
  Quote  RUN
start-144-end
13
13
[22] c$=Str$(Len(a$))
Error: A not declared
