Local Time 03:27 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : microchip EZ board
isochronic
Posted: 02:03pm 17 Oct 2016
Buried in the literature .. a Curiosity MZ EF board. Looks like the Click
modules are in favor.
Curiosity pic32MZ EF
I am wondering if all the pins on the Click i/o are compulsory or not ?
srnet
Posted: 06:53pm 17 Oct 2016
  chronic said   I am wondering if all the pins on the Click i/o are compulsory or not ?
Not 'Compulsory'.
However if you build a baseboard, such as the one you linked to, and dont provide all the specified pins, some of the Mikrobus modules that you migh want to plug in wont work and you loose the flexibility.
Google 'MikroBus'
These days the majority of companents are 3.3V, 5V only devices are not that common anymore.
It would make sense to specify the PCB sockets as 3.3V logic, leaving to the designer to deal with any 5V logic modules.
$50SAT is Silent but probably still working.
For information on LoRa visit http://www.loratracker.uk/
isochronic
Posted: 07:04pm 19 Oct 2016
I am wondering, if the footprint can be chopped down to one side only,
eg to use it via a edge-on connector for say a clock plugin or similar.
(with only using the pins on the one edge of course)
srnet
Posted: 06:48am 20 Oct 2016
  chronic said   I am wondering, if the footprint can be chopped down to one side only,
You could do.
But the Mikrobus boards are intended to be direct plug in to a breadboard as well.
