Local Time 04:04 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Serial Communication help
KRZ3
Posted: 03:47am 10 Oct 2016
I have situation where I use a unique qualifying number that changes often depending on which radio I'm talking to. My own network setup in a way. The problem is with this radio I can't get it to send a string and can only send ASCII or CHR$ data.
Is there an easy way to do the following.
Micromite one sends
ID=855
For example normally I do
Print #1,ID$+ chr$(12)+chr$(3)+ chr$(4)
Is there a easy way to break out 855 as chr$(8) + chr$(5) + chr$(5) and send the data?
Print #1,+ chr$(8)+chr$(5)+ chr$(5)+ chr$(12)+chr$(3)+ chr$(4)
Micromite 2
The receiver gets the data and puts the first 3 characters back together as the string 855 and then reads the ID so it knows if it should process the next 3 bytes?
Thanks for any help.
Posted: 04:11am 10 Oct 2016
When you say the radio module can't send strings, does that mean that you can only send data one byte at a time?
This would be unusual, but not impossible I guess.
What RF module are you using?
Most "Smart" RF modules will have some kind of input buffer of at least a handful of bytes or so, which should happily accept a string - provided it is not too long, naturally.
So-called "Dumb" modules will send data continuously if you send it to them - they simply don't care and will transmit whatever you throw at them. All checksum and any other data checking is left totally up to you.
Posted: 04:53am 10 Oct 2016
If you mean a 3-character ID, you could do
ID$="855"
Print #1,ID$ + chr$(12)+chr$(3)+ chr$(4)
Or just
Print #1,"855" + chr$(12)+chr$(3)+ chr$(4)
(those others are CTRL+L, CTRL+C, CTRL+D, or FF, ETX, EOT - just checking they're what you mean)
ASCII digit (printable) 8 would be chr$(56) not chr$(8), but it's a lot more understandable (often called "readable") as a string i.e. in quotes.
JohnEdited by JohnS 2016-10-11
KRZ3
Posted: 05:27am 10 Oct 2016
I have an email into the company asking them why it won't send the string. It's not a length issue as I can send the same data string and it will work.
If I send this it works
If I send this it won't work
That's why I was looking for a an easy way to covert the string and then reassemble when received. I never had this issue before with other radios.
The radio is the http://www.multitech.com/brands/multiconnect-mdot
It's setup in Peer to peer mode.
Posted: 05:45am 10 Oct 2016
If the first works then of course the other will not, due to ASCII encoding.
In ASCII the printable 8 has value 56 (all printable digits are offset by 48).
Print #1,"855" + ...
is thus the same as
Print #1,chr$(56)+chr$(53)+chr$(53) + ...
Don't be surprised if they reply basically telling you to look at ASCII.
KRZ3
Posted: 06:15am 10 Oct 2016
Hey John,
Thanks for the help. I apologize as I know I'm not explaining this well. I don't know the data formats and sending well at all.
I will try and explain the sequence of events.
Type on a keypad 855 or whatever 3 digit number.
so now the ID=855
I don't care what 855 looks like in ASCII or what the real value is.
I'm wondering if there is a way to separate and send individually
Print #1,+ chr$(8)+chr$(5)+ chr$(5) and then on the receiving end put it back in the same string format as 855. Unless the conversion will mess it up.
I basically need a way to send a 3 digit code and receive the same three digit code.
Posted: 06:26am 10 Oct 2016
Something like
ID3 = ID % 10
ID = (ID - ID3) / 10
ID2 = ID % 10
ID = (ID - ID2) / 10
ID1 = ID % 10 'if 3-digit, not needed, can just use ID1 = ID
Print #1, chr$(ID1) + chr$(ID2) + chr$(ID3) + ...
% is modulus i.e. remainder on division
so ID % 10 is the bottom (decimal) digit of ID
Phil23
Posted: 10:03am 10 Oct 2016
Don't quite understand the purpose of the string you are trying to send.
In particular the last 3 ASCII characters.
FF ETX EOT
And also, the string being sent will end with CR LF.
But Try a few things at the command prompt.
[Code]> dim id$ as string
> id$="855"
> print ID$
855
> print ID$+Chr$(12)+Chr$(3)+Chr$(4)
855
[/code]
It actually shows up differently on the screen, as far as the 3 low order characters go.
Why are you trying Chr$(8) 5 5 etc wouldn't this be correct?
[Code]> print Str$(8)+Str$(5)+Str$(5)+Chr$(12)+Chr$(3)+Chr$(4)
855
[/code]
As far as stripping out the digits is concerned, something like this would work,
[Code]print id$
855
> print mid$(id$,1,1) : Print mid$(id$,2,1) : Print mid$(id$,3,1)
8
5
5
[/code]
Phil
KRZ3
Posted: 03:58am 11 Oct 2016
Thanks Phil,
Some good ideas to try.
