Local Time 04:04 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Maximite - Picaxe, Serial / RS485 Comms
nasi
Posted: 05:44pm 01 Oct 2016
Hello All
This is my first post, I apologize in advance if there is a thread already covering this, however extensive browsing has eluded me to some light of help.
I am attempting to build an rs485 network around my house to control and monitor various attributes of our off grid setup.
My micro controllers of choice are maximites and picaxes as I have a surplus in the workshop.
So to cut to the chase I am struggling with Sending data from a maximite to a picaxe.
I have been reading the SNAP / Scaleable Node Address Protocol for inspiration and have had some success.
Currently I have been able to accurately control a picaxe 08m2+ with 4 relays no problems
I then increased the RS 485 network to a third node with a picaxe 18m2+
I practically took the same code from the 08m2+ and modified it to reflect the 18m2+ configuration.
The pickle I am in is that for some reason the 18m2+ simply does not want to co-operate in the same fashion as the 08m2+ which is weird and I am messing with baud rates, pauses and chip freq without any idea why the 18m2+ under the same environment will not logically function.
The issue seems to be centered around the serin command
08m2+
serin 3,T4800,(SYNC),HDB2,HDB1,DAB1,SAB1,DB1
'debug
18m2+
serin b.6,T4800,(SYNC),HDB2,HDB1,DAB1,SAB1,DB1
debug
The basic bytes of data I change respectively to poll the nominated controller.
As I said the 08m2+ works great if I remove the qualifier brackets for the 18m2+ when debugging I can get some data in but it comes through wrong the sync byte may sometimes show up correctly or in the wrong variable but its so inconsistent.
I have removed the 08m2+ from the equation to just test between the maximite and the 18m2+ still no success.
Anyway I hope this is enough info to get started and I appreciate anyones input.
Once again apologies for any lack of forum etiquette on my part.
PS, I am using the little MAX 485 modules
Link here should provide an image of the module:
http://www.aliexpress.com/item/Precise-MAX485-Module-RS-485-TTL-to-RS485-MAX485CSA-Converter-Module-For-Arduino-Integrat ed-Circuits-Products/32309776786.html
Happy to provide more info if needed.
Cheers Ladys and Gents
Richard
Posted: 06:09pm 01 Oct 2016
Hello and welcome.
Some users have found that a delay between bytes is helpful when sending from maximites/micromites to picaxes
Using two stop bits is the easiest way to achieve the delay.
I am not sure if the above is relevant for rs485.
nasi
Posted: 06:17pm 01 Oct 2016
Thank you very much for such a prompt reply.
Forgive me could you elaborate on how you would implement the stop bits,
My MM code for testing is as:
Dim DBYTE(5)
DBYTE(0) = 250 ' SYNC BYTE
DBYTE(1) = 80 ' HEADER DEFINITION BYTE 2
DBYTE(2) = 1 ' HEADER DEFINITION BYTE 1
DBYTE(3) = 50 ' DESTINATION ADDRESS BYTE
DBYTE(4) = 255 ' SOURCE ADDRESS BYTE
DBYTE(5) = 1 ' DATA BYTE (COMMAND / FUNCTION / DATA)
menu:
Cls
Print "1, Send Packet"
Print " "
Print "6, Quit Program"
Print " "
Input cmd
If cmd = 1 Then Send_PCKT
If cmd = 6 Then End
Cls
End
EndIf
GoTo menu
Sub Send_PCKT
Open "com1:4800, DE" As #1
For i = 0 To 5
Print #1, Chr$(DBYTE(i));
'Pause 50
Next
Close #1
GoTo menu
End Sub
Thanks again Jim
Bill.b
Posted: 06:30pm 01 Oct 2016
hi Nasi
This is a sample program I used to send data to a picaxe 14m2 (oled display 4 Line)
[code]
OPEN "COM1:2400, INV, S2" as #1
pause 30
Print #1,chr$(254) + chr$(1);
pause 30
Print #1,chr$(254) + chr$(128); ' line 1
Print #1,"Hello world ";
Print #1,chr$(254) + chr$(192); ' line 2
Print #1,"What a great Day";
Print #1,chr$(254) + chr$(148); ' line 3
Print #1,"to be alive";
[/code]
BillEdited by Bill.b 2016-10-03
nasi
Posted: 06:43pm 01 Oct 2016
Bill Thank you
And Thank you also Jim.
It does seem impossible until it's done.
Posted: 06:54pm 01 Oct 2016
I am not sure what the DE line does between characters of if it matters.
Here are two options to try
The first is your code with S2 in the initialise string. You can play with the pause between characters as I assume you have been doing.
The second builds the data into a string and then sends it in one go. This way the DE control line behaves as I think it should.
OPEN "com1:4800, DE, S2" AS #1
FOR i = 0 TO 5
PRINT #1, CHR$(DBYTE(i));
'Pause 50
NEXT
CLOSE #1
' make a string of the data to send first
toSend$=""
FOR i = 0 TO 5
toSend$=toSend$+
CHR$(DBYTE(i))
NEXT i
' send it in one go
PRINT #1, toSend$;
'Pause 50
CLOSE #1
nasi
Posted: 07:26pm 01 Oct 2016
S2....
ahhh ok of course thats in the manual, :)
Jim thank you for this.
I will experiments and see how I go.
Thank you again also Bill.
nasi
Posted: 11:55pm 01 Oct 2016
I figured it out Gents.
Just to give you some feedback.
It ended up being these ttl to RS485 modules.
I picked up a bunch of them online for cheap and it is starting to look as though they have somewhat of a failure rate.
But thank you all anyway.
Look forward to threading more in future.
Hopefully I can return the favour.
redrok
Posted: 11:10am 02 Oct 2016
Hi nasi;
  nasi said  It ended up being these ttl to RS485 modules.
What RS485 modules are you using?
I have been just using EXAR SP485 and SP485E chips.
redrok
nasi
Posted: 03:34pm 08 Oct 2016
I sent you a private message Redrok
Apologies in advance if breaking etiquette.
I will check out those chips, I picked these other units as they are fairly ready to hook up and obviously cheap.
Look forward to speaking more.
Richard
Bill.b
Posted: 04:07pm 08 Oct 2016
Hi nasi
When I connected a pic32mx170 to C5 (pin4) of the 14m2, I did not use any
interface modules.
I connected the output of the 170 via a 100ohm resistor to the input
of the 14m2 and all worked OK.
BillEdited by Bill.b 2016-10-10
nasi
Posted: 09:48pm 08 Oct 2016
Hey Bill
I have not done much Pic programming in C but that sounds very interesting.
I was concerned about the distance that data could be sent as I need to send around my property up to a possible 100m
I have connected some of these micro controllers up directly at TTL levels but I was under the assumption they could not handle long runs nor was it safe to do so just in case of cable potential buildup.
Please correct me if I am wrong.
Speak again soon
Richard
