Local Time 04:04 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Really Cool Gauges
Phil23
Posted: 02:00pm 01 Oct 2016
Just upgraded the software that monitors my weather station.
Really impressed with the new gauges it uses.
Basically the software just runs as an engine;
Downloads the data from the weather station;
then uploads files to my webserver.
Looking at the gauges, it's all Java Script, which I'm not familiar with, but I can interpret some of it & wonder if similar stuff can be done in MMbasic.
This is the weather data here:-
The gauges are called "Steel Series" & are on Github here.
Phil.
busa
Posted: 03:12pm 01 Oct 2016
I am impressed, that looks really good
Posted: 03:23pm 01 Oct 2016
I run Cumulus here too (running on a Pi).
I really like the charts and would like to use them for my own data but HTML in any form is not my forte.
For the gauges, if you can emulate the realtime.txt file, you should be able to adapt it relatively easily.
Phil23
Posted: 04:05pm 01 Oct 2016
  TassyJim said   I run Cumulus here too (running on a Pi).
Where's that Jim?
[Quote]For the gauges, if you can emulate the realtime.txt file, you should be able to adapt it relatively easily.
The Java is pretty well commented, someone here will understand it.
Phil.
Posted: 04:34pm 01 Oct 2016
  Phil23 said
Where's that Jim?
Phil.
I don't have it publicly available at the moment.
When I am away from home, it's easy enough to log in to my network with a VPN then access the PI as I do when home.
If I allow public access to the data, they will also have access to the configuration. I might get around to uploading to my website again (one day).
joebog1
Posted: 02:19pm 02 Oct 2016
With respect gentlemen!!
Digital stuff with analogue guages???
Must be why I still use my AVO 8 multimeter, and a HP 410B VTVM.
I have a digital CRO (philips/fluke) with the typical hash from the switchmode power supply on screen.
It also looks like ozispeedtest for the NoBloodyNetwork. AKA NBN
Joe
Phil23
Posted: 02:33pm 02 Oct 2016
Visual feedback sure beats numeric data that take more than a casual glance to read.
lew247
Posted: 11:34pm 02 Oct 2016
Joe
I think it looks totally amazing, I just wish it was possible for to make similar gauge outlines in MMBasic
Analogue guages look way nicer than digital, but these show both
Amazing
