Local Time 03:54 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MCP3302 Interfacing
Cremo
Posted: 08:58am 01 Oct 2016
Hello,
I have problems interfacing the MCP3302 A-D converter using SPI port.
My test program is the following:
_____________________________________________________
option explicit
'Chip Select A-D
const CS_MCP3302 =14
dim integer dati(3) 'to receive 3 bytes
'configure pin as Chip Select of MCP3302A
setpin CS_MCP3302,dout 'pin as digital out
pin(CS_MCP3302)=1
settick 500, Read_A_D 'periodical reading
do
loop
sub Read_A_D ' ADC reading
SPI open 1000000,0,8
pin(CS_MCP3302)=0 'chip select
spi write 3,&B00001100,&B00000000,&B00000000 'to configure chip and convert
spi read 3,dati()
pin(CS_MCP3302)=1 'chip unselect
spi close
print "data0=",hex$(dati(0))
print "data1=",hex$(dati(1))
print "data2=",hex$(dati(2))
end sub
______________________________________________________-
I see meaningless values printed.
If I connect a scope with SPI decoding I see correct values on it.
Maybe some problem in spi read from Micromite Basic ? The version I us is the 5.2 Plus version.
Thank you.
Pietro
Posted: 09:09am 01 Oct 2016
Looking briefly at the datasheet I would say you need Mode 3 rather than 0. There is definitely no problem with SPI in 5.2
Cremo
Posted: 09:35am 01 Oct 2016
Hi Matherp, thank you for your fast reply.
Changing the mode does not help.
For example if I input to the A-D a voltage to obtain a 1023 value (HEX 3FF),
I see the following values: data0= HEX FF, data1 = HEX E0, data2 = HEX 00.
Best regards.
Pietro
panky
Posted: 04:41pm 01 Oct 2016
Pietro,
Maybe a bit order problem? If you are receiving lsb first then ff e0 00 becomes 00 03 ff? Just a thought.
Doug.
Cremo
Posted: 12:45am 02 Oct 2016
Dough,
shame on me !
You are right, if I read the bits backward the values are correct.
It is only necessary to write a boring function to use the bit sequence in the correct order.
Thank you a lot.
Pietro
twofingers
Posted: 01:27am 02 Oct 2016
  Cremo said  You are right, if I read the bits backward the values are correct.
bitreverse
Cremo
Posted: 04:04am 02 Oct 2016
Hi twofingers, thank you.
Pietro
