Local Time 03:56 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Left shifting bits in mmbasic on maximite
steveizett
Posted: 11:58pm 31 Aug 2016
Hi guys
I'm playing with a hx711 and need to implement the following code.
for (i=0;i<24;i++){
ADSK=1;
Count=Count<<1;
ADSK=0;
if(ADDO) Count++;
ADSK=1;
Count=Count^0x800000;
ADSK=0;
return(Count);
How do I shift left as in "Count<<1"
I see in the manual a reference to RShift = nbr\(2^bits)
Thanks very much.
Steve
Posted: 01:32am 01 Sep 2016
Shifting one bit to the left is the same as multiplying by 2.
However the code you posted should work with a little modification as MMbasic does support shifting and XOR'ing.
From the manual page 49.
(Make sure the Count variable is an INTEGER!)
[code]
Shift operators:
x << y x >> y These operate in a special way.
<< means that the value returned will be the value
of x shifted by y bits to the left while
>> means the same only right shifted.
They are integer functions and any bits shifted
off are discarded and any bits introduced are set to zero.
[/code]
The ^ operator is called XOR in MMBasic.
(You can find that on the same page).
Edited by MicroBlocks 2016-09-02
twofingers
Posted: 01:40am 01 Sep 2016
@steveizett
LShift = nbr *(2^bits)
I think (AFAIK) the MMBasic (4.5) for Maximites has no shift operators.
... also no integers.
MichaelEdited by twofingers 2016-09-02
The lone and ...
Posted: 01:45am 01 Sep 2016
Oops, missed the Maximite reference in the topic.
Just use:
[code]
Count = Count * 2
[/code]
Posted: 12:43pm 01 Sep 2016
Remember that you are limited to about 23 bits for integers in 32 bit floating point.
steveizett
Posted: 01:13pm 01 Sep 2016
Thanks guys for the help
Sounds like I need to use micromite for this app.
Steve
