Local Time 04:16 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : sPlan jaggies
Herry
Posted: 10:04am 28 Aug 2016
I wonder if there are many users of sPlan here? I have tried to find an sPlan forum in English but have so far failed to do so. I have a particular problem in that circuit straight lines that I draw often sprout jaggies on the screen, and I cannot seem to eradicate them. When printing a circuit diagram from within sPlan, the jaggies disappear (so no doubt they are expected) but I want to use my circuit diagrams within papers and so have JPGs, which I would normally get by capturing the screen (but it still has the jaggies on). So either I need to find a way of definitely avoiding or removing the jaggies (preferable) or a way of printing to a jpg file from inside sPlan.
Input is requested, even from other sPlan users (are there enough to try and start a forum?) that have found the same problem, so I know I'm not alone!Edited by Herry 2016-08-29
Senior?!  Whatever it says, I'm a complete and utter beginner...
Posted: 05:07pm 28 Aug 2016
I use sPlan. What do you actually mean by 'jaggies' - does not compute.....
Herry
Posted: 10:16am 29 Aug 2016
By jaggies, I mean that what should be a straight line (a connection) on the screen has kinks in it.
palcal
Posted: 10:38am 29 Aug 2016
Probably like drawing a diagonal line, it becomes pixelated. I used to have the same problem with Circuit Wizard.
Paul.Edited by palcal 2016-08-30
Herry
Posted: 11:12am 29 Aug 2016
Yes, but how to solve it on sPlan? And do you know of a forum for sPlan? There must be thousands of users.
Posted: 11:46am 29 Aug 2016
If it is pixilated lines, try sticking to horizontal and vertical lines only.
45 degrees if needed are usually OK.
The printer has a much higher resolution than a display so the effect is not noticed as much.
Herry
Posted: 04:18pm 29 Aug 2016
These *are* just horizontal and vertical, but they still seem to develop kinks and I can't straighten them!
Posted: 05:20pm 29 Aug 2016
What version of sPlan? Be aware that there are updates available. Have you installed the latest updates from Abacom?
You may well have, but I don't know, so I have to ask.....
I am using sPlan 6, and the updates for sPlan(all versions) are available here:
sPlan updates
Note that the latest update is dated June 2016 for sPlan 7...
I have found Abacom to be very prompt to any problems if you email them, so if you can replicate the error, and send them a screenshot, they will see what the problem is, and can probably issue a bug-fix.
Out of interest, are you able to post a screenshot here so I can see the problem you are referring to?
skylight
Posted: 06:02am 30 Aug 2016
I'm not familiar with splan but does it have a feature to turn on anti-aliasing?
If so this will reduce the "jaggies" but at the cost of more cpu load.
I notice on the website there is a viewer that views the files in full quality I wonder if that allows printing?Edited by skylight 2016-08-31
Herry
Posted: 09:03am 30 Aug 2016
Hello all
Thanks for the input. I had sPlan 7, and this morning downloaded the latest update (25/6/16). From memory I thought there was always a notification if an update needed to be loaded and I had previously complied. Anyway, I did it.
Couldn't find anti-aliasing or the viewer.
About to do a screen capture (using Snagit (excellent program)) when out of desperation, tried again to straighten a long earth line that had jaggies somewhere on it (developing in a new place if I fixed one) however much I tried to straighten them up. Deleted it and simply drew it again. Appeared to work. BTW I use CTRL arrow to nudge lines up and down.
Posted: 09:19am 30 Aug 2016
Is there a GRID facility. Snapping to a grid makes drawing straight lines a lot easier.
Herry
Posted: 10:20am 30 Aug 2016
Yes, I have that set on. I am now surmising that the problem may be when I extend partially drawn lines. Deleting and redrawing to the full length appears to fix it.
skylight
Posted: 10:24am 30 Aug 2016
link to the viewer:
Splan viewerEdited by skylight 2016-08-31
Herry
Posted: 10:46am 30 Aug 2016
Thanks. That appears to be a very cut down version of sPlan, allowing a person to simply access sPlan files and not work on them.
