Local Time 04:14 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : uM2(+): Weird bug to be aware of
Posted: 11:44pm 22 Aug 2016
I've now been able to simply demonstrate the bug which I think is the problem in these threads.
Thread 1
Thread 2
The bug is definitely in both versions 5.1 and 5.2. I've let Geoff know separately.
Basically there is some strange interaction between
OPTION EXPLICIT
OPTION AUTORUN ON
and
CONST and LOCAL when used in MM.STARTUP
To demonstrate the bug load the following test program
Option explicit
option default NONE
option autorun on
dim integer e=4
print e
pause 1000
end
Sub mm.startup
Const a=2
Local integer b=a\2
print b
End Sub
type CPU RESTART and MM.STARTUP will execute as expected and print "1"
type RUN and the main program will run as expected and print "4". This of course also enables autorun
Now type CPU RESTART again. We expect MM.STARTUP to run and then the main program to run. MM.STARTUP runs and prints "1" but the main program fails with the error
  Quote  [1] Option explicit
Error: Variables already defined
Here is the full trace
> list
Option explicit
Option default NONE
Option autorun on
Dim integer e=4
Print e
Pause 1000
End
Sub mm.startup
Const a=2
Local integer b=a\2
Print b
End Sub
> cpu restart
1
> run
4
> cpu restart
1
[1] Option explicit
The following also gives the bug:
Sub mm.startup
local integer a=2
Local integer b=a\2
print b
End Sub
Note if you change MM.STARTUP to
[code]Sub mm.startup
Const a=2
print a\2
End Sub[/code]
The bug no longer happens
> list
Option explicit
Option default NONE
Option autorun on
Dim integer e=4
Print e
Pause 1000
End
Sub mm.startup
Const a=2
Print a\2
End Sub
> cpu restart
1
> run
4
> cpu restart
1
4
Edited by matherp 2016-08-24
Posted: 03:22am 23 Aug 2016
the following code also fails:
a=2
Option EXPLICIT
from the 5.2 manual:
  Quote  The use of OPTION EXPLICIT is recommended to support good programming practice. If it is used it should be placed at the start of the program before any variables are used.
if the word "should" is replaced with "MUST", and it is stressed that it needs to be placed in MM.STARTUP if this file is used, is the observed behaviour mitigated?
it kind of makes sense that both of the program spaces need to operate under the same set of 'rules', as they both share the same single variable space. perhaps Option EXPLICIT needs to be changed so that it is aware of already defined variables?
rob :-)
Posted: 05:40am 23 Aug 2016
  Quote  it is stressed that it needs to be placed in MM.STARTUP if this file is used
This nearly works except that if mm.startup is in the library when you load a new program then the OPTION EXPLICIT isn't active until you restart. See trace below
  Quote  library list
Sub mm.startup
Option explicit
Option default NONE
Const a=2
Local integer b=a\2
Print b
End Sub
> cpu restart
1
> 'program loaded
> list
Option autorun on
e=4
Print e
Pause 1000
End
> run
4
> 'that should have failed
> cpu restart
1
[2] e=4
Error: E not declared
> 'now it fails
Posted: 06:55am 23 Aug 2016
would it help if option explicit was a persistent setting, like option autorun is? it would then become a 'personal style' setting like selecting the colours in an editor, etc.
myself, i never use the library functions, mm.startup or mm.prompt. they make keeping track of what the micromite is doing unnecessarily confusing.
rob :-)
