Local Time 03:05 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Load and Run for Micromite MX170
MikeO
Posted: 02:25am 30 Jul 2016
MMbasic for the Micromite Plus provides a Program Load from Sdard and if you use the "R" option it will Load and Run the program automatically, no such function exists however for the MX170. Peter Mather's latest SDcard drivers have now have a Load from SDcard function so I developed the following sub routine to add Load and Run capability for the MX170.
sub BootLoad(f$)'f$ is filename to load
'print "Try to load Boot.file"
sdcard 6,f$
option autorun on
watchdog 100
pause 200
end sub
The routine may be useful as a remotely triggered program load or even provide a chaining function.
Mike
Codenquilts
Zonker
Posted: 05:12pm 30 Jul 2016
Humm... It might also be useful as a kind of program updater... Your program would scan the SD card for a known filename and if found, would flash the new one into place, then erase the the file off the SD card... So, you could E-mail someone the file, stick it on the card, and do the update, without the end user having to do things through the console... Should work for programs that don't allow the end user to ctrl-C out of the running program... nice...
