Local Time 04:36 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : ESP8266 + HC-12
Phil23
Posted: 02:59pm 28 Jul 2016
Hi All,
One for the radio guys on here & others who have done a bit with wireless devices.
At the moment I've got 3 MM's setup all with ESP8266's on the console.
2 of the 3 also have HC-12's on Com1.
Two are still setup on breadboard, and one I've been building from scratch on some strip board.
Intention is for the 2 slaves to use the HC-12's to communicate with the master.
What I have is working so far, all on default settings; not needing to send data over much more than 20 metres, (this won't change much).
What I'm wondering is how much physical separation should I try & keep between the wireless devices?
In the breadboard they are under 6 inches apart & only occasionally notice an issue, but when I get to making things more permanent I'd prefer to be informed in advance.
Some will have seen the heat pump in other posts; 1 MM will live in there; essentially in a tin can with plastic grills; and the two wireless devices could be either on the circuit board, maybe a max of 3 inches apart;
of could be on short leads to separate them a bit more.
Would greatly appreciate any input.
Also assume I should need to use much less that maximum power as well.
Phil
