Local Time 02:56 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Memory problems MK V5.1 vs V5.2
rentner111
Posted: 03:46am 26 Jul 2016
Hi Geoff !
About a problem with the memory :
I have a basic program with a length of 417 blocks .
There the PIC is used 170F256D 44 -pin .
Version : 5.1
PIC empty : MEMORY query
Flash = 60K free
RAM = 53K free
Program is transferred to the PIC and is also performed .
MEMORY query
Flash = 51k 85 % Program (1763 lines )
9k 15 % free
RAM = 28K variable 52 %
1k General
24k free
Version : 5.2
Flash = 60K free
RAM = 50K free
Program is transferred to the PIC .
Message "File tansfer completed"
then " Error : Not enough memory "
Does the version 5.2 really 15% more storage space ?
Thank you very much
Justplayin
Posted: 06:21am 26 Jul 2016
Yes, it's true, version 5.2 has less memory available due to one of the new features Geoff added. All you can do is try to make your program more memory efficient or switch to a Micromite using a 470 chip which has more RAM.
Here is a couple of things which may help reclaim some wasted memory:
1 - Use MMEdit's crunch feature to remove comments and extra spaces when your program is downloaded into the Micromite.
2 - If you are using string arrays, dimension the arrays using the LENGTH option to limit the size of the elements. By default each string element is 255 bytes long unless you define them to be less.
3 - If you are using arrays which contain only single byte values, poke the values directly into the memory space of the array and use peek to read the values. Long integers use 8 bytes per element, so poking 8 single bytes into the same space will reclaim a lot of wasted memory! Be sure to define the array accordingly though! To store 100 bytes would require an array size of only 13 elements.
--Curtis
Posted: 06:10pm 26 Jul 2016
Curtis is right, there is less RAM in 5.2 and that is limiting the size of the program that you can load. This is because the program is buffered to RAM first before being written to the flash - as a result the amount of RAM is limiting the size of the program that you can load.
Using MMEdit's crunch feature will reduce the size of the program so that it will fit. Another approach is to split your program into two parts, then load the first part and save it to the library using LIBRARY SAVE. You can then load the second part and your program should run. This is because loading the program in two parts avoids hitting the limit imposed by the lesser amount of flash.
Yet another option is to stick with 5.1. So long as your program runs fine on it there is no need to change.
