Local Time 04:52 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Bitwise AND/OR
thirsty
Posted: 11:36pm 18 Jul 2016
Hi Guys
So I've got this statement:
PORT(2,3,7,4,9,1)=&B10011001
What I'd like to do is conditionally change the first bit. I know I can AND/OR to change it but I'm not sure of the syntax.
I was thinking:
PORT(2,3,7,4,9,1) AND &B10000000
Would that work?
Posted: 03:19am 19 Jul 2016
A little reference:
[code]
Truth tables:
AND
| 0 | 1
0 | 0 | 0
1 | 0 | 1
OR
| 0 | 1
0 | 0 | 1
1 | 1 | 1
[/code]
AND only gives a 1 when both values are 1
OR only gives a 0 when both values are 0
This is for a single bit. So each single bit is used when AND or OR numbers.
If you want to make a single bit 1 then use OR with a bit 1 in that position.
If you want to make a single bit 0 then use AND with a bit 0 in that position.
Edited by MicroBlocks 2016-07-20
thirsty
Posted: 02:57pm 19 Jul 2016
Thanks for that.
Do you know the syntax to do that in MMBasic?
Posted: 04:45pm 19 Jul 2016
I think you can read the state of pins that have been set as outputs. If so,
currentstate = PORT(2,3,7,4,9,1) ' read the current settings
otherpins = currentstate AND &B01111111
toppin = currentstate AND &B10000000 ' value is 128 if set or zero if not set
'to set top pin leaving the other pins as they were
PORT(2,3,7,4,9,1)=&B10000000+otherpins
' to reset top pin
PORT(2,3,7,4,9,1)=&B00000000+otherpins ' or just PORT(2,3,7,4,9,1)=otherpins
If that doesn't work, you will need to keep a record of the settings of the other pins.
Posted: 07:37pm 19 Jul 2016
i feel i must be missing something. what is wrong with:
pin(9) = 1
to set the top bit high,
pin(9) = 0
to clear the top bit, and,
pin(9) = not pin(9)
to flip the top bit?
(assuming the LAST pin specified in a PORT command is the topmost bit, just checked the manual and corrected post for this)
rob :-)Edited by robert.rozee 2016-07-21
thirsty
Posted: 08:52pm 19 Jul 2016
Actually Rob you are quite right - I think I was just trying to be a bit too clever :) and focusing on the need to change the pattern over the entire port range. The bit I'm trying to turn on/off is indeed on a particular pin and I can just turn it on or off by using the Pin command.
Thanks again all.
