Local Time 05:10 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Operating Valves.
Phil23
Posted: 11:09am 11 Jul 2016
Hi All,
Looking for some feedback on operating my ball valves.
They will only move a few times a day.
I know I can just call a Sub & have the main loop suspended for 10 or 15 seconds while I wait for the valve to move & the limit change, then return to the main loop.
But can I move & check them in the background?
It's not super important for the valves, but once I start adding Coms, I'd rather not have the main loop pausing every time data is exchanged between different MicroMites.
Similar code could be applied to both needs.
Phil.
Phil23
Posted: 03:36pm 11 Jul 2016
Thinking along the lines of a Subroutine that activates the appropriate relay when called, then returns to the main loop while the valves are in motion.
Probably checking the limits every 5 seconds to see they do reach their destination and also shutting the relay off after a timeout of 30 seconds.
I get the impression it might need a SETTICK Sub, but don't want to fall in the trap of calling that same sub from my main routine & getting tied up in recursive calls.
Phil.
