Local Time 05:03 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Hexadecimal to Decimal Conversion HELP!
2001cpx
Posted: 05:38am 07 Jul 2016
Tried in many way to Convert this Hexadecimal (for exemple):
0997D8738A that give 41202250634 in Decimal
i currently use Maximite and Micromite GCmicroboard2b
Thanks In Avandce ,i like MMbasic!!!!
"Color Maximite,(Duinomite-Mega,Mini),CGmmStick,GCmicroboard2b,Micromite + explore 64,100,LCD backpack,Lcd Backpack V2,TFT Backpack,Micromite Extreme,Armmite L,F,H,CMM2"
Posted: 06:05am 07 Jul 2016
Assuming 0997D8738A is a string
i.e. s$="0997D8738A"
then
dim integer i=val("&H"+s$)
works perfectly on the Micromite. It won't work properly on the Maximite as the number is too big to be held accurately as a floating point numberEdited by matherp 2016-07-08
Posted: 06:11am 07 Jul 2016
As a consideration: I would have a FOR i = 1 TO LEN(xxx$)...NEXT i loop where xxx$ is the Hex string input you wish to convert. NOTE: check len(xxx$)>0 first!
Then, starting at right hand side (using MID$(xxx$,len(xxx$)+1-i,1) in the above For..Next loop), take each character and convert to a decimal value between 0 and 15 (i.e. call a Sub with 16 Case Selects). Multiply this value (between 0 and 15, inclusive) by 2^(i-1) where i = position in xxx$.
This will achieve answer, but there are other ways too . . . .
WW
I just knew Peter would beat me to it!!Edited by WhiteWizzard 2016-07-08
2001cpx
Posted: 07:03am 07 Jul 2016
I fell off my chair ..... I made a very complicated multiplication routine that was not working, A big thanks !!
RESOLVED
Thanks Matherp and WhiteWizzard!!!
Phil23
Posted: 10:21am 07 Jul 2016
  matherp said
s$="0997D8738A"
then
  WhiteWizzard said  I would have a FOR i = 1 TO LEN(xxx$)...NEXT i loop where xxx$ is the Hex string input you wish to convert.....
Wo,
If was a dead heat I'd still give it to Peter in Simplicity.
My immediate thought was also pull the string apart & multiplying the digits by powers of 2.
Cheers.
Posted: 08:27pm 07 Jul 2016
  Phil23 said   .... I'd still give it to Peter in Simplicity.
I agree, but only if needing this for a MicroMite; however note 2001cpx's possible requirement for a MaxiMite too
Posted: 10:21pm 07 Jul 2016
  Quote  however note 2001cpx's possible requirement for a MaxiMite too
My code will work on a Maximite just as well as on a Micromite.
The issue on a Maximite is that all numbers are stored as floating point with a 24-bit mantissa. The number in 2001cpx's example needs more bits than that to be stored accurately. It doesn't matter what technique is used to do the conversion the limitation still applies
Posted: 10:29pm 07 Jul 2016
@matherp
In simple terms, what is the biggest HEX number (either in terms of length, or value) that will give an accurate result.
I would try out, but all my Maxi's are still in boxes (somewhere ).
Posted: 10:34pm 07 Jul 2016
  Quote  In simple terms, what is the biggest HEX number (either in terms of length, or value) that will give an accurate result.
24-bits = 6 HEX digits
I can't remember if the mantissa has a sign bit so it may be &H7FFFFF is the biggest positive number
Of course bigger numbers can be stored with loss of accuracy
e.g. &H7FFFFFxxxxxxx
where the x values aren't usedEdited by matherp 2016-07-09
Posted: 03:00am 08 Jul 2016
what we need is some kind soul to help geoff out by back-porting the micromite code to run on the maximite, complete with the vga output of course
rob :-)
