Local Time 05:14 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : How to... with MM
kiiid
Posted: 11:29pm 24 Jun 2016
... undefine a pin?
Imagine this setup - 64-pin MM+ with a switch connected to ground on pin 51.
According to the Manual, pin 51 is the WAKE pin so it should bring the MM back to active after CPU SLEEP. But how to use the switch to go to sleep? If I set it up as DIN, then CPU SLEEP generates an error "pin 51 is in use"...
http://rittle.org
Posted: 11:37pm 24 Jun 2016
  Quote  ... undefine a pin?
SETPIN pn OFF
kiiid
Posted: 12:36am 25 Jun 2016
SETPIN pn OFF
Cool! I will try it now.
http://rittle.org
kiiid
Posted: 11:51pm 02 Jul 2016
How to make a font with transparent background?
http://rittle.org
Posted: 01:09am 03 Jul 2016
My driver for the R61505V does this - just use 1 as the background colour. I've also written drivers for the SSD1963 which do this - same approach. It can't be done with the standard drivers as it relies on reading the background colour. Otherwise you would have to cursor position for each pixel in the font
kiiid
Posted: 01:32am 03 Jul 2016
Fortunately, in this case I am using exactly your R61505V driver, so that's excellent news. Thank you!
http://rittle.org
