Local Time 00:07 26 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Program size and choosing which Micromite
lew247
Posted: 07:32am 19 Jun 2016
This is going to seem a stupid question for you experts in Pic programming and so on but to me it's a blank
How do I work out what size a program will take once it's programmed into the micromite?
And
how do I know if I will need a 28 pin Micromite or a Micromite + ?
The reason I ask is I tried loading part of the weather program into the micromite today and it failed with the error not enough memory or words to that effect
Edited by lew247 2016-06-20
Phil23
Posted: 11:06am 19 Jun 2016
Try typing memory at a prompt to see what is used & available with different bits of code.
I was playing with some code that I'd heavily added bits to, commented bits out, duplicated bits with different scenarios....
It was using 76% in the MX170.
Used the "Crunch Option" in MMedit to strip it all down & it was heaps smaller.
Don't remember figures.
Posted: 05:12pm 19 Jun 2016
Often memory is used up by fonts and in that case you can load the fonts first and save them in the library (LIBRARY SAVE). That compresses the font and saves a lot of memory.
lew247
Posted: 08:36pm 19 Jun 2016
Thanks Geoff and Phil23
Phil23
Posted: 09:43pm 19 Jun 2016
  Geoffg said   Often memory is used up by fonts and in that case you can load the fonts first and save them in the library (LIBRARY SAVE).
When you say "Load them First" how is that achieved?
Does it mean you load a BAS file that contains only the fonts, with say MMedit, and then issue the LIBRARY SAVE command at the prompt?
IE,
[Code]
' embedded fonts
' Font: Hom_16x24_LE
' Includes all ASCII characters
DefineFont #2
5F201810 00000000 00000000 00000000 00000000 00000000 00000000 00000000
00000000 00000000 00000000 00000000 00000000 00000000 80010000 80018001
80018001 80018001 00018001 00010001 00000000 80010000 00008001 00000000
00000000 00000000 00000000 00000000 00000000 00000000 98190C0F 0000F030
End DefineFont
[/code]
Phil.
palcal
Posted: 10:07pm 19 Jun 2016
Phil,
Yes that is exactly how it is done.
Paul.
Phil23
Posted: 10:10pm 19 Jun 2016
Please ignore the above....
I just read the manual.
Thanks.
mikeb
Posted: 09:47am 20 Jun 2016
Geoff must be getting tired of us saying 'We just read the manual'
Posted: 03:48pm 20 Jun 2016
  Phil23 said   Please ignore the above....
Thanks.
LOL!!!!
We've all been there, Phil.
Welcome to the club.
palcal
Posted: 08:08pm 20 Jun 2016
WHEN ALL ELSE FAILS READ THE INSTRUCTION BOOK.
Paul.
mikeb
Posted: 05:28pm 22 Jun 2016
Hi all,
If I am guilty, in future, don't waste your time with an explanation. Just respond with 'RTFM'. Not looking for a quick answer but a 'pointer' in the right direction.
I certainly won't take offence.
Posted: 10:09pm 22 Jun 2016
I have been working with MMs from the early days, and have written & developed many programs for literally hundreds of MMs. However, I still refer to the excellent manual at least twice a day and often learn something new!
Do not underestimate the manual's content (even if you think you 'know it all'). Geoff has created a masterpiece IMHO. Not too complicated, enough detail, and great examples.
May not be to everyones 'format' - but at least refer to it first if you are stuck with something.
All that said, if you are a 'beginner', the manual can seem daunting (but still worth a read )
