Forum Index : Microcontroller and PC projects : If Else Execution.
Phil23
Posted: 11:49am 14 Jun 2016
Regarding Executions of IF statements.
Am I correct in thinking that once an IF or ELSE IF statement returns TRUE,
that the remaining test statements are skipped?
IE. Test1=False, Test2=True, Tests 3 & 4 are then ignored?
[Code]
IF Test1 THEN
Instruction1
Else IF Test2 THEN
Instruction2
Else IF Test2 THEN
Instruction2
Else IF Test3 THEN
Instruction3
Else IF Test4 THEN
Instruction4
END IF
[/code]
Phil
CircuitGizmos
Posted: 01:04pm 14 Jun 2016
Try it.
Phil23
Posted: 04:02pm 14 Jun 2016
  CircuitGizmos said   Try it.
Not near any of my MM stuff this morning,
Hence churning over code in my head re a logic solution.
Cheers.
Will get to try some test code later....
Posted: 09:32pm 14 Jun 2016
The answer is "Yes".
Careful juggling with the order of the statements can make a big difference to the complexity and performance.
You might also want to consider SELECT..CASE as a cleaner option, depending on your conditional statements.
