Forum Index : Microcontroller and PC projects : Default Baud Rate.
| Phil23 Guru Joined: 27/03/2016 Location: AustraliaPosts: 1667 |
Not suggesting a change, but just curious as to the choice of 38400. Also is 115200 likely to reduce reliability with ESP8266's? And for Jim, is MMchat happier with 38 or doesn't really care. Thanks Phil |
A bit like Goldilock's porridge... not too fast and not too slow but just right. Geoff Geoff Graham - http://geoffg.net |
| paceman Guru Joined: 07/10/2011 Location: AustraliaPosts: 1329 |
Errr - that'd be 'not too hot and not too cold' Geoff. I know this because I've been recently boning up on Goldilocks with the grandchildren. Still, I'm sure we get your drift
Greg |
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6608 |
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10048 |
You've been boning up on Goldilocks paceman? Smoke makes things work. When the smoke gets out, it stops! |
Yes, but I was trying for a humorous analogy. Geoff Geoff Graham - http://geoffg.net |
Ummm, yes and no Grogs. Thought I might edit that word but that would have called attention to it. |
