Local Time 05:47 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : uM2(+) :micro-second timing
Posted: 05:23am 04 Jun 2016
When tuning code it is useful to know how long things are taking and the Micromite is now so fast that the 1-millisecond resolution of the "timer" variable isn't always sufficient.
The attached CFunctions allow you to zero the Micromites internal tick clock and then read it, automatically scaled by the CPU speed to give microsecond readings. The code works on both the Micromite and the Micromite+
Of course the command to set the clock and read it takes time so this needs to be measured and subtracted from the code being tested. I do this in the attached test code
option explicit
option default none
dim integer a
dim float b
zerotimer()
a=gettimer() 'measure how long the clock takes to zero and read
zerotimer()
b=atan2(1.5.1.6)
? gettimer()-a," usec" 'print the time taken to execute the function
end
CSub zerotimer 'zero the tick clock
00000000
00001021 40824800 03E00008 00000000
End CSub
CFunction gettimer 'get the number of microseconds since the tick clock was zeroed
00000000
40044800 3C029D00 8C420000 3C03001E 34638480 8C450000 00A3001B 006001F4
00001812 0083001B 006001F4 00001821 03E00008 00001012
End CFunction
FUNCTION atan2(y as float,x as float) as float
IF x > 0 THEN
atan2 = ATN(y/x)
ELSEIF y >= 0 AND x < 0 THEN
atan2 = PI + ATN(y/x)
ELSEIF y < 0 AND x < 0 THEN
atan2 = ATN(y/x) - PI
ELSEIF y > 0 AND x = 0 THEN
atan2 = PI / 2
ELSEIF y < 0 AND x = 0 THEN
atan2 = PI / -2
ENDIF
IF atan2 < 0 THEN
atan2 = atan2 + 2 * PI
ENDIF
END FUNCTION
C-source
void zerotimer(void){
unsigned int current_ticks = 0;
asm volatile("mtc0 %0, $9": "+r"(current_ticks)); //set the current number of ticks to 0
long long gettimer(void){
unsigned int current_ticks;
asm volatile("mfc0 %0, $9" : "=r"(current_ticks));//get the time in ticks since zeroed
unsigned int tick_rate;
tick_rate = CurrentCpuSpeed /2000000; //get the number of clock ticks per usecond
return current_ticks/tick_rate;
Edited by matherp 2016-06-05
drkl
Posted: 02:10am 05 Jun 2016
Dear Matherp,
Here is the line from the program:
b=atan2(1.5.1.6)
What does it mean?
1.5.1.6 is a number?
I don't understand.
Can you explain for me?
Thank you
drkl
Posted: 03:01am 05 Jun 2016
  Quote  What does it mean?
I don't understand.
Should be 1.5,1.6
atan2 is just an example trig function (written by TassJim I think) that I was using to measure the execution duration.
Not sure how the comma became a dot
Zonker
Posted: 08:38am 05 Jun 2016
Humm... Would there be a way to turn this very precise timing into a trigger timer..? Like for SCR or triac control... I would like to create a 3 phase controller to control 6 SCR's in such a way to allow full 4 quadrant selection, so the output would be programmable from negative, through 0 and swing into the positive side of voltages.... If you provide 3 zero cross triggers, the timer would then output the precise timing to 3 (or 6) output pins to activate the SCR's... With this setup, you could the create some very high power MM touch panel controlled units..! With some current feedback devices added, maybe a LEM sensor, you could control max power delivered to a load...Nice..!
EDIT: I would pay money for this..! Edited by Zonker 2016-06-06
Posted: 03:51am 06 Jun 2016
  Zonker said  I would like to create a 3 phase controller to control 6 SCR's in such a way to allow full 4 quadrant selection, so the output would be programmable from negative, through 0 and swing into the positive side of voltages.... If you provide 3 zero cross triggers, the timer would then output the precise timing to 3 (or 6) output pins to activate the SCR's [...] With some current feedback devices added, maybe a LEM sensor, you could control max power delivered to a load...
what you have described is called a "soft starter", basically the equivalent of 3 very large light dimmers used to ramp up (and down) the power applied to a 3-phase motor. i've spent quite a bit of time testing these for Aucom Electronics (a christchurch, nz based manufacturer of soft starters).
one application is in water pumping systems, to prevent mechanical damage at startup. they are also far friendlier than VFDs in terms of electrical noise injected back into the grid (when up to speed the soft starter is bypassed).
see:
http://www.aucom.com/en/
rob :-)
Edited by robert.rozee 2016-06-07
drkl
Posted: 07:08pm 07 Jun 2016
Hello,
I try:
zerotimer()
zerotimer()
'here is the measurable program part, now is nothing
optime=gettimer()-a ' MUST SUBSTRACK SOME VALUE?
? optime," usec" 'print the time taken to execute the program-part
end
The result is:
> RUN
9 usec
So,
You should not use any correction?
drkl
Posted: 09:43pm 07 Jun 2016
  Quote  So,
The program is doing exactly what is should. With no measurable part the output should be approximately zero. In fact the interpreter has to step over the comment which takes some time which you seem to be measuring at 9 usec. The idea of my example program was to show how to measure the time taken to do the "measurable" section by removing the time to set up and read the timer
drkl
Posted: 05:34am 08 Jun 2016
Perfect!
drkl
