Local Time 05:47 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : com2 close error?
drkl
Posted: 09:38pm 29 May 2016
Hello everybody,
mm44,ver5.2
The code:
open "com2:9600" as #1 'MM44: pin30-TX PIN31-RX
close #1
setpin 30, off
The error message:
[3] SetPin 30, off
Error: Pin 30 is in use
What is the error?
drkl
Posted: 09:48pm 29 May 2016
Not by a MM at the moment. Out of interest what happens if you add a PAUSE (try 1000) after the CLOSE line and before the SETPIN?Edited by WhiteWizzard 2016-05-31
Posted: 09:59pm 29 May 2016
I would also agree with WW - a small pause - probably 100ms would be enough between your close #1 and setpin 30 would most likely get around that issue.
jwaldha
Posted: 10:13pm 29 May 2016
I think this is a bug in the firmware in the line 255 of the MX170/Serial.c:
if(ExtCurrentConfig[COM2_RX_PIN] == EXT_COM_RESERVED) ExtCfg(COM2_TX_PIN, EXT_NOT_CONFIG, 0);
The correct line:
if(ExtCurrentConfig[COM2_TX_PIN] == EXT_COM_RESERVED) ExtCfg(COM2_TX_PIN, EXT_NOT_CONFIG, 0);
JWaldha
JWaldha
drkl
Sorry,
the delay doesn't solved the problem.
May it be a firmware bug?
drkl
Posted: 11:58pm 30 May 2016
It is a bug!
Thanks very much, your test program made it so easy to find.
It will be fixed in the next release.
