Local Time 05:56 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : is it possible to display long numbers ?
f1fco
Posted: 10:06am 23 May 2016
hello,
I need to use long numbers (integers) like
123456789
I receive a string (m$) as "098765432"
when I convert in number (Val(m$)) result was 9.87654e+07
is it possible to display and use the "real" number 98765432 ?
thank you for help
Pierre, from Nimes, south of France
73s de F1FCO
Posted: 12:12pm 23 May 2016
What version of MMBasic are you running.
If it's a version that does integers:
DIM n AS INTEGER
m$ = "098765432"
PRINT VAL(m$)
n = VAL(m$)
PRINT n
PRINT STR$(n,10)
PRINT STR$(n,12)
> RUN
98765432
98765432
98765432
98765432
If you don't declare the number type, it will default to floating point.
f1fco
Posted: 01:34am 24 May 2016
hello Jim,
I use v4.5 on a Maximite
but I try also v5 on a Micromite and it is ok with the type integer n!
no issue with a 4.5 on a Maximite ?
Pierre.
73s de F1FCO
Posted: 01:54am 24 May 2016
  Quote  no issue with a 4.5 on a Maximite ?
Numbers on the Maximite are stored as floating point with a 24-bit mantissa. This means the maximum accuracy is normally 7 decimal digits and only 6 for numbers where the mantissa is greater than 8388607Edited by matherp 2016-05-25
Posted: 08:04pm 24 May 2016
Using V4.5 on a Maximite, you can get a bit more using FORMAT$.
S$="1234567890"
t = val(S$)
print format$(t,"%10.0f")
Note that this does NOT get around the limitations of 32bit floating point maths.
The result from the above code will not display the same as the initial string.
Depending on what you are doing, you may have to break the numbers up into usable sizes.
A few years ago, I wrote a program to do integer maths with strings.
' integer maths by TassyJim 07 Feb 2012
a$ = "13"
FOR i = 0 TO 15 ' demo of the four operations
add( a$ , STR$( i ),res$ )
PRINT a$;" + ";i;" = ";res$
min( a$ , STR$( i ),res$ )
PRINT a$;" - ";i;" = ";res$
multy( a$ , STR$( i ),res$ )
PRINT a$;" * ";i;" = ";res$
div( a$ , STR$( i ),res$ )
PRINT a$;" / ";i;" = ";res$
PRINT
NEXT i
a$="1"
FOR i = 1 TO 55 ' printing up to factorial 55.
b$=STR$(i)
multy(a$, b$, res$)
PRINT b$;"! = ";res$;" (";LEN(res$);" )"
a$=res$
NEXT i
END
SUB div( a$ , b$, c$ ) ' given a$ and b$, returns a/b in c$
LOCAL f, i, d, t, try$, nr$, a1$, b1$, a2$, z$
a1$=a$ : b1$=b$ : c$="" ' make copies of a$ and b$ to preserve originals
IF VAL( b$ ) = 0 THEN ' divide by zero
c$ = "error"
ELSE
FOR i = LEN( a1$ ) - LEN( b1$ ) TO 0 STEP -1
f = 0
nr$ = "0"
z$=STRING$(i,"0")
FOR d = 0 TO 9
md( b1$ + z$ , d, try$ )
big( a1$ , try$, t )
IF t THEN
f = d
nr$ = try$
ENDIF
NEXT d
c$ = c$ + STR$( f )
IF f > 0 THEN
min( a1$ , nr$, a2$ )
a1$ = a2$
ENDIF
NEXT i
ENDIF
trim (c$)
END SUB
SUB multy( a$ , b$, c$ ) ' given a$ and b$, returns the sum in c$
LOCAL i, h$, a1$, b1$, t$, d$, z$
IF LEN( b1$ ) > LEN( a1$ ) THEN ' swap number for greater speed
h$ = a1$
a1$ = b1$
b1$ = h$
ENDIF
FOR i = LEN( a1$ ) TO 1 STEP -1
z$=STRING$(LEN( a1$ )-i,"0")
md( b1$ , VAL( MID$( a1$ , i , 1 ) ) , t$)
add( c$ , t$+ z$ ,d$)
c$=d$
NEXT i
trim (c$)
END SUB
SUB md( a$ , nr, c$ ) ' multiply a$ by a single digit, result in c$
LOCAL hold, carry, i
carry = 0 : c$=""
FOR i = LEN( a$ ) TO 1 STEP -1
hold = VAL( MID$( a$ , i , 1 ) ) * nr + carry
carry = INT( hold / 10 )
c$ = STR$( hold MOD 10 ) + c$
NEXT i
IF carry > 0 THEN c$ = STR$( carry ) + c$
END SUB
SUB samelen (a$, b$) ' pads the shorter variable with leading zeros
dif=ABS(LEN( a$ )-LEN( b$ ))
IF dif>0 THEN
z$=STRING$(dif,"0")
IF LEN( a$ ) < LEN( b$ ) THEN
a$ = z$+a$
ELSE
b$ = z$+b$
ENDIF
ENDIF
END SUB
SUB add( a$ , b$, c$ ) ' given a$ and b$, returns the sum in c$
LOCAL carry, hold, i,a1$, b1$
c$="" : a1$=a$ : b1$=b$
samelen a1$ , b1$
hold = VAL( MID$( a1$ , i , 1 ) ) + VAL( MID$( b1$ , i , 1 ) ) + carry
x$=STR$( hold MOD 10 )
c$ = RIGHT$( x$,1) + c$
NEXT i
END SUB
SUB min( a$ , b$, c$ ) ' given a$ and b$, returns the difference in c$
LOCAL a1$, b1$, h$, i, hold, borrow
c$="" : s$="" :a1$=a$ : b1$=b$ ' initialise variables and preserve a$ and b$
samelen a1$ , b1$
IF a1$<b1$ THEN ' if result is going to be negative, swap a1 & b1
h$ = a1$
a1$ = b1$
b1$ = h$
s$="-"
ENDIF
hold = VAL( MID$( a1$ , i , 1 ) ) - VAL( MID$( b1$ , i , 1 ) ) + 10 - borrow
borrow = 1- INT( hold / 10 )
NEXT i
trim c$
c$ = s$+c$ ' add the sign
END SUB
SUB big( a$, b$, biggest ) ' biggest = 1 if a$ >= b$
LOCAL a1$, b1$ 'preserve a$ and b$
a1$ = a$ : b1$ = b$
biggest = 0
samelen (a1$ , b1$)
IF a1$>=b1$ THEN biggest = 1
END SUB
SUB trim (a$) ' given a$, leading zeros are stripped. a$ is altered.
LOCAL s$
s$=""
IF LEFT$(a$,1)="-" THEN ' if the number is negative, preserve the sign
s$="-"
a$=MID$(a$,2)
ENDIF
DO WHILE LEFT$(a$,1)="0" ' strip leading characters while they are "0"
a$=MID$(a$,2)
LOOP
IF a$="" THEN a$="0"
a$=s$+a$ ' replace the sign
END SUB
f1fco
Posted: 11:47pm 24 May 2016
thank you Jim,
I have tried FORMAT... but the result is not exactly the same as the string
no problem, my project run perfectly on a Micromite with integers
Pierre.
73s de F1FCO
