Local Time 05:56 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : while PLUS until
kiiid
Posted: 05:32am 23 May 2016
Only today I discovered that it is impossible to make a structure DO WHILE .... LOOP UNTIL
Would it be too hard to have it? Increases flexibility significantly if the two conditions are different.
http://rittle.org
CircuitGizmos
Posted: 06:59am 23 May 2016
You can't test the "UNTIL" condition at the end of the loop and exit (EXIT DO) the loop?
kiiid
Posted: 08:24am 23 May 2016
Of course I can (and do), but it is not as elegant :)
http://rittle.org
Posted: 12:02pm 23 May 2016
What about
EXIT DO
Posted: 02:03pm 23 May 2016
While it can be done it would not be BASIC as we know it and it would be messy to explain. Also, I am not sure that it would be "elegant", rather the opposite because most people reading the program would be thoroughly confused.
vegipete
Posted: 07:56am 24 May 2016
How about:
DO
<statements>
IF condition THEN EXIT
LOOP
Chris Roper
Posted: 08:21am 24 May 2016
  vegipete said   How about:
DO
<statements>
LOOP
Is that not the same as:
DO
<statements>
UNTIL condition
http://caroper.blogspot.com/
Posted: 10:18am 24 May 2016
  kiiid said   Only today I discovered that it is impossible to make a structure DO WHILE .... LOOP UNTIL
If you mean
DO WHILE exp1 .... LOOP UNTIL exp2
then it's trivial to do as people have posted.
C has the same way of solving it and it works really well.
In effect you do
DO WHILE exp1
IF exp2 THEN EXIT
LOOP
(bit hazy on MMBasic syntax)
vegipete
Posted: 09:47am 25 May 2016
DO
<statements>
LOOP
DO
<statements>
UNTIL condition
Exactly the same in my books. But I realize upon reflection that neither is exactly what kiiid asked for in the original posting.
I was taught that a 'DO <stuff> UNTIL <condition>' structure is appropriate when you need to do the <stuff> at least once. In contrast, the 'WHILE <condition> <stuff> DO' structure can result in the <stuff> never being done. (Like household chores sometimes.)
So kiiid wants something that will do <stuff> at least once based on one condition but possibly not at all based on a different condition. The logic starts to get a bit hairy...
Chris Roper
Posted: 10:21am 25 May 2016
  vegipete said  So kiiid wants something that will do <stuff> at least once based on one condition but possibly not at all based on a different condition. The logic starts to get a bit hairy...
How about:
[code]
IF condition1 MySub
Do While condition2
MySub
Loop
[/code]
Posted: 12:33pm 25 May 2016
I believe the right answer for what was asked has been posted, though it's quite possible that some other thing was meant.
There are several common idioms in C (and wow are there a lot of examples on the net) for this kind of thing and they translate easily into MMBasic without needing weird or repeated code.
JohnEdited by JohnS 2016-05-26
