Local Time 05:56 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Converting other basic to Micromite Basic
lew247
Posted: 09:22am 19 May 2016
I'm "TRYING" to learn/work out the differences between the types of basic compared to Micromite Basic so I can convert Bascom and Picaxe programs if and when needed.
If anyone is able to help me, could you tell me what each of the lines below would be in Micromite Basic please?
[code]
'Data array for i2c communication
Dim Value_array (24) As Byte
Dim Ut As Long
Declare Sub I2c_write (byval Device_adres As Byte, byval Reg_adres As Byte, byval value As Byte)
Declare Function test1() As Long
Declare Function test2_64 () As Dword
Txt = Str (t)
Txt = format (txt, "00.00")
Sub I2c_read (device_adres As Byte, Reg_adres As Byte, Value_count As Byte)***
Local X As Byte (dim X As Byte????? can I miss out the Local bit???)
Local Y As Byte
Y = Value_count - 1
Shift Up, Left, 8
Up = Up + Value_array (2)
Local Var1 As Long
Local Var2 As Long
Local X As Long
Local Var1 As Double
Shift X, Right, 2, Signed
I2cstart
I2cwbyte Device_adres
I2cwbyte Reg_adres
I2cwbyte value
I2cstop
I THINK the last bit should be (not sure what cwbyte means though)
i2c open 400,1000 '400KHz bus speed
i2c close
[/code]
I can work out most of it myself, but the bits above I'm totally stuck on what they mean or would be in Micromite Basic
Phil23
Posted: 01:14pm 19 May 2016
Bascom looks like it has 8 types of variables instead of the 3 in MMbasic.
So for BYTE, WORD, DWORD & LONG use INTEGER.
For SINGLE & DOUBLE use FLOAT.
Found some good stuff here.
Phil
lew247
Posted: 08:54am 22 May 2016
Anyone else able to help?
Posted: 12:23pm 22 May 2016
I don't know Bascom and don't know what device you are trying to talk to so I can only guess.
I2cwbyte is probably short for
I2C WRITE BYTE
In MMBasic, I would try
I2C WRITE Device_adres, 1, 2, Reg_adres, value
