Local Time 05:56 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : defaultPin
Nathan
Posted: 12:32pm 15 May 2016
Please let me present defaultPin V1.0.
It is a C-Function, which sets all unfonfigured pins
to one of the following modes or just output the
unconfigured pins.
' mode: function:
' 0 print actual unconfigured pins
' 1 input, pull down
' 2 input, pull up
' 3 output, low
' 4 output, high
defaultPin(mode)
supported are 28, 44 and theoretically also 64 and 100 pin package.
Unfortunately I could not check functionality for 64 and 100pin packages,
yet. I would be happy about feedback for the devices.
The console pins will not be set by the function. At the end of the
attached c-function is the black list for the device pins, which are ignored
by the function.
2016-05-15_222817_defaultPin_V1.0.zip
I would also be happy about users, which use MBASIC special functions like
count, I2C ....
A short Usage Example:
defaultPin(0)
Output on Console:
001
002
003
004
005
008
009
010
011
013
015
defaultPin(1)
defaultPin(0)
--> no output, all unfonfigured pins are set to inpt, pull down
Background:
A io-buffer (pin), which is not configured. Is in a high-Z state,
which may generate a cross current within the input P/N-Fet transistor
pair. This can cause unexpected cross current and reduction of liftetime.
If possible avoid floating conditions as much as possible.
Have fun,
Nathan
Edited by Nathan 2016-05-17
Zonker
Posted: 04:46pm 16 May 2016
Interesting info about unused pins in our designs and a very useful Cfunction..!!
Thanks Nathan..
Posted: 06:09pm 16 May 2016
  Nathan said  A io-buffer (pin), which is not configured. Is in a high-Z state, which may generate a cross current within the input P/N-Fet transistor pair. This can cause unexpected cross current and reduction of liftetime. If possible avoid floating conditions as much as possible.
No, this is not an issue with the Micromite. All pins have a Schmitt Trigger input so they are either on or off and never in a half way state. However, grounding unused pins makes them immune to static discharge.
GeoffEdited by Geoffg 2016-05-18
Nathan
Posted: 07:34pm 16 May 2016
Hi Geoff,
the schmitttriger circuits are enabled in case the pins
are configured as digital input. Please take a look into Chapter 12
of the design manual regarding configuration and state of the
ports.
My explanation with the two transistor model is a little bit to simple.
A real estimation would be possible only with an exact knowledge of the
transistor circuit structure.
In case the schmitttriger is enabled. We are talking about cmos
and not bipolar transistor circuits. The activation energy is very low
for cmos.
Immunity against discharge should be independent of the state of a
device. The human body and machine model will be tested without
power connection, mostly. It is a pin to pin check.
A good designed device survices > 2KVolt pulses(following the spec).
Some applications requires > 4KV.
There is an ISO norm for this available.
Nathan
Edited by Nathan 2016-05-18
Posted: 04:24am 17 May 2016
  Nathan said  the schmitttriger circuits are enabled in case the pins are configured as digital input.
Any unconfigured pins are set as digital inputs.
  Nathan said  Please take a look into Chapter 12 of the design manual regarding configuration and state of the ports.
Thanks but I do know how to configure the I/O ports and I have read the manual.
atmega8
Posted: 06:53am 17 May 2016
Geoff, that's typicall german behaviour, sorry
https://en.wikipedia.org/wiki/Nathan_the_Wise
Nathan the Wise
Posted: 01:17pm 17 May 2016
Sorry, yes I should have realised it was just a cultural thing.
Nathan's program is great but I don't want people concerned that there is a design fault. Floating pins are OK except if ESD is a concern and then they should be grounded.
That was an interesting link to the Ring Parable. Thanks.
Posted: 05:28pm 17 May 2016
I am from the Netherlands and if Germans are known for something (except drinking beer ) then it is the attention to detail!
There are lots of little details hidden in the hundreds of pages of datasheet and this one was new for me. Good to see that it was handled.
atmega8
Posted: 07:24pm 17 May 2016
Soccer Microblocks Soccer;-)Edited by atmega8 2016-05-19
Posted: 01:52am 18 May 2016
1974 still hurts!
Posted: 01:59am 18 May 2016
over on the HP calculator museum forums the members frequently have brawls over quite innocent cultural and linguistic misunderstandings. we are talking about blood on the floor, broken bones, and the occasional death.
and i must confess, that i myself can at times be a tad acerbic. plus i use obscure words far too often! in person i am far more mild-mannered.
rob :-)
CircuitGizmos
Posted: 03:47am 18 May 2016
I'll add acerbic to my vocab. Trenchant and caustic were lonely.
Nathan
Posted: 10:23am 20 May 2016
Hmmm,
interesting discussion.
Some days offline and completely off topic.
So lets start.
1.) Documentation of the microcontroller.
> Chapter 12 also contains recommentdation about the open pin handling
> IT also has drawings about the port structure
--> MicroBlocks
2.) Nathan the Wise.
Thanks for the flowers, do you know the story?
"Nathan the Wise" by Gotthold Ephraim Lessing in 1779.
(performance was forbidden for a long time)
Next try.
3.) Nathan's program is great but I don't want people concerned that there is a design fault.
--> There is no design fault.
--> A floating pin has to be avoided, so the user has to take care,
to clamp it or to set it to output. There is a cross current in other case.
Please use a search engine and take a look onto the pictures.
CMOS uses other circuts then bipolar transistors. CMOS uses move of
the switch levels.
4.) the only important point for me:
Does the function works with 64 and 100 pin chips?
NathanEdited by Nathan 2016-05-21
Nathan
Posted: 03:36am 22 May 2016
Microchip has a very good document on their download page.
Please search for: AN1785
Document title: "ESD and EOS Causes, Differences and Prevention"
The document is brilliant and completely matches with the things
I'm seeing at work.
Regarding unused pins, please take a look onto page 20.
On page 28 is a LEM picture, which looks very similar to
the situation of a floating unused pin inverter transistor pair.
(smaller ones, the big one is a damage)
small add on: There is an other Microchip document, which is also helpfull
search for AN1416
Title: "Low-Power Design Guide"
It explains a lot about the technology, too. Actual main process modes
are 40nm, 28nm and 16nm and are not covered (document is of 2011)
but it is still helpfull.
Nathan Edited by Nathan 2016-05-23
Posted: 05:00am 22 May 2016
That paper and everything that you have been talking about refers to normal CMOS inputs. The PIC32 has Schmitt trigger inputs.
Nathan
Posted: 05:39am 22 May 2016
Hi Geoff,
sorry the Schmitt trigger situation is very similar to the inverter.
It only depends a little bit on implementation.
VDD
p1 p3
+ +Va
p2
+----------output
n1
n2 n3
+ +Vb
VSS
p - p-channel fet
n - n channel fet
gates of p1, p2, n1, n2 are tied together and are the input.
p1, p2,n1,n2 are in series connected.
p3 and n3 are switched in parallel depends of level at output
and build up the Schmitt trigger by moving the switch level.
(circuit for this is not drawn). There are different possibilites for
connection and control of n3, p3 and depends on IO library and
patent situation. Every vendor has a little bit different implementation
for Va, Vb.
Cross current between n1, n2, p1, p2 is the point and this depends
on the gate voltage, which is the same for all 4 transistors.
There is also a nice discussion on electronics.stackexchange.com
look for "general rule of thumb for unused ic pins"
ST also has a nice document: AN3430
title: "Application note How to achieve the lowest current consumption with STM32F2xx"
page 6, shows port structure with schmitt trigger input
page 7, recommendation for open input
Please let us stop this discussion.
I only want to know if it works for 66 and 100 pin package.
No one must use the function.
Nathan
