Local Time 06:01 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM+ Counter frequency
Tinine
Posted: 11:21pm 14 May 2016
I need to reliably and constantly keep a pulse count of approximately 100KHz. Missing a beat due to other chip activity is not an option. Is this possible?
Cheers!
Tinine
Posted: 11:35pm 14 May 2016
Yep, configuring a pin as a counting input will count at up to 300KHz. This is done in the background and it will not miss a count.
Look for the command: SETPIN nn, CIN
You have four I/O pins that can be used for this function.
Tinine
Posted: 03:45pm 16 May 2016
Cool!
So no difference between MM and MM+ then?
Cheers!
Tinine
