Forum Index : Microcontroller and PC projects : microchip ARM Cortex M4 etc
| isochronic Guru Joined: 21/01/2012 Location: AustraliaPosts: 689 |
Hmmm. https://www.microchip.com/en/pressreleasepage/microchip-introduces-hardware-cryptography-enabled-32-bit-microcontroller- for-internet-of-things-applications ?! |
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10048 |
404 not found. Space in address. Might have been put there by forum software or typo. Here is a clickable link for chronic's post above..... Smoke makes things work. When the smoke gets out, it stops! |
Thanks Grogster - (I should use the hyperlink I know) So... anyone soldered a 144-WFBGA package yet ?! Can that be done with solder paste and .. and .. (sob) and whats with the non MIPS ?! Lots of sram I see, but at 48 Mhz; I don't know if MPLABX will compile for it. Interesting. |
