Local Time 06:03 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 7 bits datas on a Maximite ?
f1fco
Posted: 05:54am 13 May 2016
is it possible to receive 7 bits serial datas on a Maximite ?
firmware 4.5
Pierre.
73s de F1FCO
Posted: 05:59am 13 May 2016
No. It is 8 bit data with one or two stop bits.
f1fco
Posted: 06:03am 13 May 2016
thank you for fast answer Geoff
and 7 bits, is it possible on a MicroMite ?
I need to read datas on 7 bits from a power counter and 8 bits is a garbage...
perhaps with a C function ?
or a future, or special, version of the firmware
PierreEdited by f1fco 2016-05-14
73s de F1FCO
Posted: 06:14am 13 May 2016
If it is 7 bits with two stopbits then you could configure for 8 bits with one stopbit and then disregard the one bit extra by masking it of.
f1fco
Posted: 06:41am 13 May 2016
I find the Serialrx function here :
http://www.thebackshed.com/forum/forum_posts.asp?TID=7963&KW=serialrx
is it possible for the Gurus of Cfunction to have a version with the choose of numbers of bits ?
7 for me !
thank you very much
Pierre.
73s de F1FCO
Posted: 07:14am 13 May 2016
How many stop bits are with the 7 data bits?
You might say what is creating them to help people...
JohnEdited by JohnS 2016-05-14
f1fco
Posted: 07:24am 13 May 2016
1200 or 9600 bauds
7 bits datas
even parity
1 stop
Pierre.
73s de F1FCO
Posted: 07:36am 13 May 2016
8 bit 1 stop bit will work
The total number of bits that are send are still 9
7 bits + parity + stop = 9 bits.
8 bits + stop = 9 bits.
Just disregard the parity bit.
Best is to examine the values by looking at their binary representation.
Without the last bit the received data should make sense.
Posted: 07:51am 13 May 2016
what he said!
Justplayin
Posted: 08:33am 13 May 2016
Seems like 8N1 should work, then AND the received data with "01111111" to remove the parity bit.
--Curtis
Posted: 08:55am 13 May 2016
@Geoff, would that not be a good addition to MMBasic to support 7 bits?
As described above it can be done in software if the peripheral does not support it.
There are lots of sensor and equipment that work with 7 bits and toggling/masking some bits in C is trivial.
Edited by MicroBlocks 2016-05-14
