Local Time 06:01 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : RTC problem with a CGColorMax1
f1fco
Posted: 05:32am 13 May 2016
I own a CGColorMax1 with firmware 4.5 (mm.ver -> 4.05)
but I cannot have the RTC
if I update date and time (DATE$="13/05/16" and TIME$="17:00:00", I lost date and time when I shutdown power supply
I not have the message under the Maximite logo saying that the clock is not set
why ???
is it a special version of firmware for the CGColorMax1 ?
please, help me
Pierre, from Nimes, south of France
73s de F1FCO
f1fco
Posted: 05:48am 13 May 2016
curious, on my board the +5v is only 3.98 V !
with a scope, I have not the 32768 Hz oscillations on pins 1 and 2 of the DS1307
and of course no signals on SDA/SCL outputs
Pierre.
73s de F1FCO
Posted: 05:52am 13 May 2016
Do you have a backup battery installed? The RTC will not work without it, even when powered normally.
f1fco
Posted: 06:08am 13 May 2016
the BR1225 battery is on the board
3.27V
and also 3.27V on the pin 3 of DS1307
73s de F1FCO
