Local Time 03:05 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMEDIT INCLUDE
drkl
Posted: 02:32am 03 May 2016
Hello,
How can use the MMEDIT Include directive?
I try, but it is not operates. My mistake, it is sure.
It would be better a sample code
drkl
Posted: 07:38am 03 May 2016
One for TassyJim when he wakes up - and something I need a little more info about too
@TassyJim - can you please provide me a link to the latest version of MMEdit as I have been 'offline' for a few weeks and am keen to catch up! - Thanks Jim
EDIT: Can you also link me to the latest Font Editor too if possible (so much to catch up on )
Edited by WhiteWizzard 2016-05-04
Posted: 01:12pm 03 May 2016
I missed the INCLUDE section out of the help file when I changed to CHM format.
Here is the text from the original help file:
  Quote  To make it easier to reuse code, you can add your library files using two methods.
In the Edit menu, you can Insert a file at the current location (actually after the current line) or at the end of the file.
The second method requires INCLUDE directives.
In the main code a comment line with either ‘$INCLUDE:’ (Quick Basic style) or ‘#INCLUDE’ (C style) with indicate where the include file is to be placed.
Running ‘merge include files’ from the ‘Program’ menu will insert the library files into the main file. A comment line will be inserted at the end of the include file so you know what code was added. The original include directive has another comment (‘) added to prevent subsequent merges from adding a second copy of the include file.
An include file can have its own includes.
In both cases, the added code is now part of the main file.
The following code:
Newdate$= date$
mainloop:
DOW (Newdate$, weekday, day$) ' returns day of week as number and string
splitdate (Newdate$, day, month, year)
toJD (day, month, year, jd) ' returns Julien Day Number
print today$;" "weekday;" ";day$ ;" - JD number: ";format$(jd,"%12.0f")
input "New Date", Newdate$
if Newdate$<>"" then goto mainloop
end
'$INCLUDE: date.bas
Will become:
Newdate$= date$
mainloop:
end
''$INCLUDE: date.bas
' given date as string, returns day, month, year
sub splitdate (currentdate$, d, m, y)
d= val(mid$(currentdate$,1,2))
m= val(mid$(currentdate$,4,2))
y= val(mid$(currentdate$,7,4))
end sub
'given day, month, year
'dayz=days since 1/1/1900 - agrees with Excel after 1/3/1900
sub toMSday (d, m, y, dayz, dayofyear)
dayofyear= d+int((m-1)*30.57+0.5)
if m>2 then
dayofyear= dayofyear-1
if (y mod 4)>0 then dayofyear= dayofyear-1
endif
dayz= int((y-1900)*365.25-0.25)+dayofyear+1
end sub
' given date as string, returns day of week as number and string
sub DOW (currentdate$,weekday, day$)
local d, m, y, dayz
weekday= abs((dayz-1) mod 7)
day$=mid$("SunMonTueWedThuFriSatSun",weekday*3+1,3)
end sub
' input day, month, year - returns julien day number
sub toJD ( d, m, y, jd)
ff = fix((m-14)/12)
jd = fix((1461*(y+4800+ff))/4)+fix((367*(m-2-12*ff))/12)-fix((3*(fix(y+4900+ff)/100))/4)+d-32075
end sub
'input julien day - returns day, month, year
sub fromJD (jd, d, m, y)
local l, n, i, j
l = jd + 68569
n = fix(( 4 * l ) / 146097)
l = l - fix(( 146097 * n + 3 ) / 4)
i = fix(( 4000 * ( l + 1 ) ) / 1461001)
l = l - fix(( 1461 * i ) / 4 )+ 31
j = fix(( 80 * l ) / 2447)
d = l - fix(( 2447 * j ) / 80)
l = fix(j / 11)
m = j + 2 - ( 12 * l )
y = 100 * ( n - 49 ) + i + l
end sub
'End INCLUDE
Everything between ''$INCLUDE: date.bas and 'End INCLUDE
was in the file date.bas
'$INCLUDE: date.bas and '$INCLUDE date.bas are identical.
Include files can be either in the code source folder or preferably in a separate ‘include’ folder.
I will be changing the INCLUDE section to allow for adding the INCLUDE's during 'load and run', leaving the source file as is.
@WW
The latest MMEdit is a few weeks old but available from my website.
Search here for latest Font Tweak. I will put it and the other utilities on my website eventually.
disco4now
Posted: 01:54pm 03 May 2016
Thanks Jim, this will be good.
F4 H7FotSF4xGT
drkl
Posted: 07:34pm 03 May 2016
Jim, many thanks,
Thank you the quick and exact answer.
I tested, it operates well.
Beside this, the original solution is remains?
drkl
Posted: 08:17pm 03 May 2016
drkl
Yes, it will continue to work the same way as well as the extra option.
MikeO
Posted: 03:19pm 31 Jul 2016
Hi Jim, this include directive does not seem to work with the macro upload function to Teraterm , is that correct. I use that method all the time and the include working with this would be very useful, is it possible?
Mike
Codenquilts
Posted: 05:30pm 31 Jul 2016
Are you using the 'normal' file "lastfile.bas" or the 'crunched' one "lastfile.baz"?
I would rather not touch the normal one but I could add the INCLUDE to the crunched one. It shouldn't cause any grief for other users.
It will add more time delays every time users do a 'save'.
MikeO
Posted: 06:10pm 31 Jul 2016
Hi Jim, I just use the crunched one, hardly ever use the other so that's not a drama. Its just that I have started using the Library memory area in the Umite and being able to add in include files that I know are change free to the one main file would be really useful.
Perhaps an option switch?
Cheers Mike Edited by MikeO 2016-08-02
Codenquilts
