lew247 Guru Joined: 23/12/2015 Location: United KingdomPosts: 1709
Posted: 11:26pm 19 Apr 2016
Does anyone have any of these displays?
I need the physical dimensions in mm of the pcb mounted on the back of the display
including the mounting holes position and dimensions
if anyone has one of these I'd be grateful
I've got the 7" one so it's only the smaller ones I need please.
Phil23 Guru Joined: 27/03/2016 Location: AustraliaPosts: 1667
Posted: 01:38am 20 Apr 2016
I've got one here.
It's a 5 inch.
What dimensions do you want?
Phil
Grogster Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10048
Posted: 03:41am 20 Apr 2016
I have 3.2", 5" and 7" footprints. I can send them to you as gerber files you can import into your own PCB program if you like - PM me if interested.
These are all the 1963 parallel interface type LCD's, and have the mounting holes and the 4-way connector in the footprint.Smoke makes things work. When the smoke gets out, it stops!
Posted: 04:25am 20 Apr 2016
Grogster that would be ideal if you could please?
Exactly the details I was hoping to get
I'll message you my email address
Posted: 04:29am 20 Apr 2016
Acknowledged.Smoke makes things work. When the smoke gets out, it stops!
