Local Time 06:25 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Android BT Terminal
Phil23
Posted: 02:31pm 12 Apr 2016
Hi All,
Any suggestions for a Serial Terminal app that Supports VT-100.
Have tried a few, but most don't respond to the menu button (or Recent), on my Galaxy S7, so can't get them configured.
Only one I've found so far that I can connect with is just straight ASCII.
BT Simple Terminal
Thanks.
srnet
Posted: 07:20pm 12 Apr 2016
Blueterm+ was the most complete implementation I came across but some commands are missing, you cannot set a scroll window is one I recall.
But positioning text etc works well enough.
$50SAT is Silent but probably still working.
For information on LoRa visit http://www.loratracker.uk/
Phil23
Posted: 07:32pm 12 Apr 2016
Thanks Srnet,
That's one I've tried, but cant access its menu on the S7.
The menu button brings up the Split Screen message on the new Samsungs.
srnet
Posted: 07:46pm 12 Apr 2016
  Phil23 said   Thanks Srnet,
Ah, the usual problem with 'standard' operating systems, they keep changing them.
