Local Time 01:09 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : uMite Interrupts making me crazy
viscomjim
Posted: 04:54pm 06 Apr 2016
I am loosing it or something...
This program works only one time after startup and I can not figure out why. I turn on the interrupts and sit in a loop. When I pull one of the pins low, it will print out which one it is and then won't work again until I power cycle the unit. I do the setpin X, din to disable the interrupts so that it can't be interrupted while doing something in the sub, then I re-enable the interrupts again and it just sits in the main2 loop and can't be interrupted again. WHY????
Thanks for any and all help with this!!!!
Also, the four pins are pulled high with external 10k resistor.
MAIN:
SetPin 2, INTL, TRIGGERED1 'Input from Trigger 1
SetPin 3, INTL, TRIGGERED2 'Input from Trigger 2
SetPin 4, INTL, TRIGGERED3 'Input from Trigger 3
SetPin 5, INTL, TRIGGERED4 'Input from Trigger 4
PRINT "TURNED ON INTERRUPTS"
MAIN2:
GOTO MAIN2
SUB TRIGGERED1
SETPIN 2, DIN 'TURN OFF INTERRUPT
SETPIN 3, DIN 'TURN OFF INTERRUPT
SETPIN 4, DIN 'TURN OFF INTERRUPT
SETPIN 5, DIN 'TURN OFF INTERRUPT
PRINT "TRIGGER ONE INTERRUPT OCCURED"
GOTO MAIN
END SUB
SUB TRIGGERED2
PRINT "TRIGGER TWO INTERRUPT OCCURED"
GOTO MAIN
END SUB
SUB TRIGGERED3
PRINT "TRIGGER THREE INTERRUPT OCCURED"
GOTO MAIN
END SUB
SUB TRIGGERED4
SetPin 3, DIN 'TURN OFF INTERRUPT
SetPin 4, DIN 'TURN OFF INTERRUPT
SetPin 5, DIN 'TURN OFF INTERRUPT
PRINT "TRIGGER FOUR INTERRUPT OCCURED"
GOTO MAIN
END SUB
Edited by viscomjim 2016-04-08
Posted: 05:22pm 06 Apr 2016
You are GOTO'ing out of a SUB instead of a normal END SUB
As well as being a no-no, I think you need to END SUB to turn the interrupts back on.
Try setting a flag in the sub and re-initializing the interrupts when the flag has been set.
Posted: 05:30pm 06 Apr 2016
Try this:
DIM triggered
MAIN:
SETPIN 2, INTL, TRIGGERED1 'Input from Trigger 1
SETPIN 3, INTL, TRIGGERED2 'Input from Trigger 2
SETPIN 4, INTL, TRIGGERED3 'Input from Trigger 3
SETPIN 5, INTL, TRIGGERED4 'Input from Trigger 4
MAIN2:
IF triggered = 1 THEN
triggered = 0
ENDIF
GOTO MAIN2
SUB TRIGGERED1
triggered = 1
END SUB
SUB TRIGGERED2
triggered = 1
END SUB
SUB TRIGGERED3
triggered = 1
END SUB
SUB TRIGGERED4
triggered = 1
END SUB
Posted: 05:47pm 06 Apr 2016
While you can probably get away with it, my understanding is that you should not be running code of more then a line or two inside an interrupt. The idea being to deal with the interrupt ASAP, and then exit from that interrupt - don't hang around inside one changing things.
I would tend to set some flags in the interrupts, and have the main loop change the SETPIN commands from the main loop based on the flags.
...but that is just me, and if it works for you(with Jim's mods), then.....
Posted: 06:58pm 06 Apr 2016
Does this not work:
[code]
DO
LOOP
SUB TRIGGERED1
END SUB
SUB TRIGGERED2
END SUB
SUB TRIGGERED3
END SUB
SUB TRIGGERED4
END SUB
Edited by MicroBlocks 2016-04-08
panky
Posted: 06:59pm 06 Apr 2016
I think Jim is all over it. By using GoTo's inside the interrupt handler, you never actually exit the interrupt service routine. Worse than that, if another interrupt were to occur and be serviced, you would be recursively calling the interrupt service routine which would eventually run out of memory.
Jim's example code is a great lesson on code layout, particularly the indenting which shows straight away the problem. The experts always say "Try to NOT use goto unless there is a very,VERY good reason to do so." With Geoff's implementation of MMBasic, you can use subroutines and do loops to achieve the same thing but much safer than goto.
Cheers,
Doug.
