Local Time 01:09 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : VT-100 Control Commands
Phil23
Posted: 03:42pm 06 Apr 2016
Hi All,
Can anyone point me in a good directions for some VT-100 Command sequences.
Have looked at a few data sheets already.....
What I want to do is replicate some of the data displayed on the LCD Back Pack on the terminal screen once I've connected the MicroMite remotely.
At present I'm just using PRINT & the data continuously scrolls off the screen with each update.
Phil
Posted: 04:08pm 06 Apr 2016
A good starting point is Geoff's VT100 terminal
http://geoffg.net/terminal.html
There are a couple of links at the bottom of the page.
Justplayin
Posted: 04:12pm 06 Apr 2016
Do a Google search for "ANSI escape codes". Lots on info out there just be aware there are a couple of interpretations so you may need to experiment a little.
--Curtis
