Local Time 01:09 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM-V5.1 SDcard driver for 28 and 44-pin
Posted: 05:28am 01 Apr 2016
Please find attached a new driver for the SD card on the 28 and 44-pin Micromite. This is now a complete implementation of PetitFAT so it will work with both FAT and FAT32 formatted cards. It also now supports reading a directory. The function calls have been simplified using new 5.1 features.
The example code includes two variants of the CFunction, one works with the normal SPI pins as per the manual but should be fully compatible with TFT panels and touch. The second uses the second SPI channel on the Micromite to connect to the SD card. Pins for the second channel are:
28-pin: SPI2OUT-24, SPI2IN-6, SPI2CLK-26
44-pin: SPI2OUT-11, SPI2IN-23, SPI2CLK-15
Just use MMEdit to comment/uncomment the version of the CFunction you require.
As before it is important to understand the major limitation of the PetitFAT system. Data can only be written into pre-existing files. So to use the code for logging, a large empty file should be created and stored on the SD card. This can then be written into by the PetitFAT code. Files and/or directories cannot be created or deleted.
There is one Cfunction that supports all access to the SD card and it has 6 modes of operation. In all cases the Cfunction returns 0 for success and a positive non-zero value in the event of an error
OK = 0,
Disk Error = 1,
Not Ready = 2,
File does not exist = 3,
File not open = 4,
Not mounted = 5,
No valid filesystem = 6
In addition the directory read call returns a value of -1 when the last directory entry has already been read.
The six functions are:
initialise and mount the disk
open a file
read from a file
write to a file
open a directory for read
read the next directory entry
These are defined as constants in the program:
' Constants defining SD card calls
const mount=0
const fileopen=1
const readfile=2
const writefile=3
const opendir=4
const readdir=5
The calls in this new version have been simplified as follows:
ret%=SDcard(mount,SD_CS_pin_number)
This initialises and mounts the SD card using the defined pin number for the chip-select
ret%=SDCard(fileopen,filename$)
This opens the file defined by the string literal or variable "filename$".
ret%=SDcard(readfile,buff$ or buff(),start_byte,#_of_bytes_requested,#_of_bytes_read)
This reads a specified number of bytes into a Basic variable
"buff" defines where the bytes read will be put. For 255 bytes or less this should be a string variable e.g. buff$. For greater than 255 bytes it should be an integer array dimensioned such that the number of bytes requested divided by 8 should be less than or equal to the array size e.g. DIM INTEGER buff(127) can receive 1024 bytes
"start_byte" defines the number of bytes from the start of the file to start the read. Use zero to position at the beginning of the file. Use any negative number to read from the current file location
"#_of_bytes_requested" defines the number of bytes you wish to read.
"#_of_bytes_read" returns the number of bytes actually read. This should be the same as the number requested unless the end-of-file has been reached so it provides an easy test for end-of-file
ret%=SDcard(writefile,buff$ or buff(),start_byte,#_of_bytes_to_be_written,#_of_bytes_written)
This writes a specified number of bytes from a Basic variable
"buff" defines where the bytes to be written are stored. For 255 bytes or less this should be a string variable e.g. buff$. For greater than 255 bytes it should be an integer array dimensioned such that the number of bytes to be written divided by 8 should be less than or equal to the array size e.g. DIM INTEGER buff(127) can store 1024 bytes for output to the SDcard.
"start_byte" defines the number of bytes from the start of the file to start the write. Use zero to position at the beginning of the file. Use any negative number to write from the current file location
"#_of_bytes_to_be_written" defines the number of bytes you wish to write.
"#_of_bytes_written" returns the number of bytes actually written. This should be the same as the number requested unless the end-of-file has been reached so it provides an easy test for attempting to write past the end-of-file
ret%=SDCard(opendir,directoryname$)
This opens the directory defined by the string literal or variable "directoryname$".
ret%=SDCard(readdir,filename$)
This reads the next filename from the open directory and returns it in the string variable "filename$". NB the return value is -1 if the last file was previously read. Sub-directories are indicated by the prefix "<DIR>"
The code has been tested on both 28 and 44-pin Micromites with both FAT and FAT32 formatted SD cards.
The C code is attached:
2016-04-01_151330_SDCardV201.zip
Also attached the demo to display the tiger, this assumes the TFT display is enabled (OPTION LCDPANEL ILI9341.....) and that the SD driver is already loaded and saved in the library. This hasn't been tested as I don't have a suitable display available until later next week - please let me know.
Of course with the new directory read facility it would now be easy to make the Micromite display all the pictures on an SD card in sequence
2016-04-01_152624_newpic.zip
' Demo of reading directory and logging data on a Micromite using the PetitFAT SD card driver
option explicit
option default none
const mount=0
const fileopen=1
const readfile=2
const writefile=3
const opendir=4
const readdir=5
CONST CTRL_Z = 26 'Used in example as EOF marker
const CS_PIN=24 'Chip select pin conected to the SD card
dim integer i,filepos,num
dim s$
prepnumbers()
' Mount the disk
if(SDcard(mount,CS_PIN)) THEN : Print "Unable to mount Disk" : END : ENDIF
' open directory
if(SDcard(opendir,"")) THEN : Print "Unable to open directory" : END : ENDIF
'read the directory
do
i=SDcard(readdir,s$)
if i>0 then : Print "Unable to read directory" : END : ENDIF
if i=0 then print s$
loop while i<>-1
' Open a file to use for write
IF(SDCard(fileopen,"empty.txt")) then : print "Unable to open file" : END : ENDIF
' Write out a title line
s$="Title: 73 times table "+chr$(13)
IF(SDcard(writefile,s$,0,len(s$))) THEN : PRINT "Unable to write file" : END : ENDIF
' maintain the file pointer - this must be done in the Basic program
filepos=len(s$)
num=0
' write out 500 lines of output updating the file pointer as we go
for i=1 to 500
s$=int2text$(num)+chr$(13)
num=num+73
IF(SDcard(writefile,s$,filepos,len(s$))) THEN : PRINT "Unable to write file" : ENDIF
filepos=filepos+len(s$)
next i
' write something we can recognise as the end of file
s$=chr$(CTRL_Z) 'end of file marker CTRL-Z
' Now lets read back the file to check it
' Read in the first 240 characters positioning the filemarker to the beginning of the file
if(SDcard(readfile,s$,0,240,filepos)) THEN : PRINT "Unable to read file" : END : ENDIF
print s$;
' loop through the file
do 'NB we call readfile with
if(SDcard(readfile,s$,-1,240,filepos)) THEN : PRINT "Unable to read file" : END : ENDIF
if instr(s$,CHR$(CTRL_Z)) THEN
s$=left$(s$,instr(s$,CHR$(CTRL_Z))-1)
filepos=0
endif
print s$;
loop while filepos<>0 'loop until the end of the physical file or our end-of-file marker
print ""
end
CFunction SDcard 'SPI1 version
0000062F
'rcv_spi
240300FF 3C02BF80 AC435820 3C03BF80 8C625810 30420080 1040FFFD 3C02BF80
8C425820 03E00008 304200FF
'xmit_spi
308400FF 3C02BF80 AC445820 3C03BF80 8C625810 30420080 1040FFFD 3C02BF80
'mem_set
10C00006 00801021 00862021 A0450000 24420001 5444FFFE A0450000 03E00008
00000000
'mem_cmp
2407FFFF 24C6FFFF 10C70008 00001021 80830000 80A20000 00621023 14400003
24840001 1000FFF7 24A50001 03E00008 00000000
'mystrlen
80830000 10600006 00001021 24420001 00821821 80630000 5460FFFD 24420001
03E00008 00000000
'MtoC
00801021 80870000 10E0000A 00802821 24830001 00873821 10600004 00000000
90660000 A0A60000 24A50001 1467FFFA 24630001 03E00008 A0A00000
'send_cmd
27BDFFE0 AFBF001C AFB20018 AFB10014 AFB00010 309100FF 7C111420 04410009
00A09021 24040077 00002821 0411FFF4 00000000 2C430002 10600034 8FBF001C
3231007F 3C109D00 8E030090 8E02001C 80640030 0040F809 24050006 0411FFA3
00000000 8E030090 8E02001C 80640030 0040F809 24050005 0411FF9C 00000000
02202021 0411FFA4 00000000 00122602 0411FFA1 00000000 7E443C00 0411FF9E
00000000 7E443A00 0411FF9B 00000000 324400FF 0411FF98 00000000 24020040
12220006 24040095 3A310048 24020001 24030087 00402021 0071200A 0411FF8E
00000000 2410000A 0411FF80 00000000 7C021C20 04610004 2610FFFF 321000FF
1600FFF9 00000000 8FBF001C 8FB20018 8FB10014 8FB00010 03E00008 27BD0020
'disk_readp
27BDFFD8 AFBF0024 AFB40020 AFB3001C AFB20018 AFB10014 AFB00010 00809021
00C09821 00E0A021 3C029D00 8C42008C 8C4300FC 30630008 00051240 24040051
0043280A 0411FFA6 00000000 14400024 24100001 34109C40 241100FF 0411FF5B
00000000 14510005 2610FFFF 1600FFFB 00000000 1000001A 24100001 240300FE
14430017 24100001 00138823 26310202 12600006 02348823 0411FF4C 00000000
2673FFFF 1660FFFC 00000000 02548021 0411FF46 00000000 A2420000 26520001
1650FFFB 00000000 0411FF40 00000000 2631FFFF 1620FFFC 00000000 00008021
3C029D00 8C430090 8C42001C 80640030 0040F809 24050006 0411FF34 00000000
02001021 8FBF0024 8FB40020 8FB3001C 8FB20018 8FB10014 8FB00010 03E00008
27BD0028
'clust2sect
24A5FFFE 8C830008 2463FFFE 00A3182B 10600005 00001021 90830002 8C820014
70A32002 00821021 03E00008 00000000
'dir_rewind
27BDFFE8 AFBF0014 AFB00010 00A08021 A4A00000 8CA50008 24030001 10A30015
24020001 8C830008 00A3182B 50600012 8FBF0014 54A00008 AE05000C 90830000
24020003 54620008 AE00000C 8C850010 10A00005 AE05000C 0411FFDD 00000000
10000003 AE020010 8C820010 AE020010 00001021 8FBF0014 8FB00010 03E00008
27BD0018
'create_name
27BDFFE0 AFBF001C AFB10018 AFB00014 00A08021 8C910004 02202021 24050020
2406000B 0411FF09 00000000 8E080000 00002021 00001821 24070008 2409002F
2406002E 240A0008 01031021 90420000 24630001 2C450021 14A00018 306300FF
50490017 01031821 10460003 0087282B 14A00008 2445FF9F 54EA0011 01031821
5446000F 01031821 01402021 1000FFEE 2407000B 30A500FF 2CA5001A 10A00003
02242821 2442FFE0 304200FF A0A20000 24840001 1000FFE4 308400FF 01031821
AE030000 2C420021 A222000B 00001021 8FBF001C 8FB10018 8FB00014 03E00008
27BD0020
'get_clust
90840000 24020003 14820006 00001821 90A30015 00031A00 90A20014 00621825
00031C00 90A2001B 00021200 90A4001A 00441025 03E00008 00621025
'get_fat
27BDFFE0 AFBF001C 2CA20002 1440001B 24030001 8C820008 00A2102B 10400018
00601021 000519C2 8C82000C 30A6007F 27A40010 00622821 00063080 24070004
0411FF31 00000000 1440000C 24030001 93A30013 00031E00 93A20012 00021400
00621825 93A20010 00621825 93A20011 00021200 00621825 7C63D800 00601021
8FBF001C 03E00008 27BD0020
'dir_next
27BDFFE0 AFBF001C AFB20018 AFB10014 AFB00010 00808821 00A08021 94B20000
26520001 3252FFFF 12400028 24020003 8CA30010 50600026 8FBF001C 3242000F
54400021 A6120000 24630001 ACA30010 8CA5000C 14A00007 00121902 94830004
0243182B 14600017 24020003 10000018 8FBF001C 90820002 2442FFFF 00621024
54400011 A6120000 0411FFBA 00000000 00402821 2C430002 1460000C 24020001
8E230008 00A3182B 10600008 24020003 AE05000C 02202021 0411FF39 00000000
AE020010 A6120000 00001021 8FBF001C 8FB20018 8FB10014 8FB00010 03E00008
27BD0020
'dir_find
27BDFFD8 AFBF0024 AFB30020 AFB2001C AFB10018 AFB00014 00809821 00A08821
00C09021 0411FF31 00000000 14400021 00408021 96260000 30C6000F 02402021
8E250010 00063140 24070020 0411FED2 00000000 0002802B 16000017 02001021
92420000 50400013 24100003 9242000B 30420008 14400008 02602021 02402021
8E250004 2406000B 0411FE55 00000000 10400008 02602021 02202821 0411FF9F
00000000 1040FFE3 00408021 10000002 02001021 02001021 8FBF0024 8FB30020
8FB2001C 8FB10018 8FB00014 03E00008 27BD0028
'follow_path
27BDFFE0 AFBF001C AFB20018 AFB10014 AFB00010 00809021 00A08021 AFA7002C
80E20000 24030020 14430006 00C08821 24E70001 AFA7002C 80E20000 5043FFFD
24E70001 2403002F 54430004 AE000008 24E70001 AFA7002C AE000008 8FA2002C
90420000 2C420020 10400008 02002021 02402021 02002821 0411FEE7 00000000
1000001B A2200000 02002021 27A5002C 0411FF02 00000000 14400015 02402021
02002821 02203021 0411FFA0 00000000 14400010 8FBF001C 8E030004 9063000B
5460000D 8FB20018 9222000B 30420010 10400006 02402021 02202821 0411FF28
00000000 1000FFE8 AE020008 24020003 8FBF001C 8FB20018 8FB10014 8FB00010
03E00008 27BD0020
'pf_lseek
27BDFFD8 AFBF0024 AFB30020 AFB2001C AFB10018 AFB00014 00808021 1080004F
24020005 90830001 30630001 1060004B 24020004 8C82001C 0045902B 00B2100A
00409021 8C830018 AC800018 12400043 00001021 90910002 10600012 00118A40
2463FFFF 2642FFFF 0051001B 022001F4 00001012 0071001B 022001F4 00002012
0044102B 54400008 8E050020 00111023 00431824 AE030018 02439023 10000003
8E050024 8E050020 AE050024 0232102B 10400018 00119823 02519023 02002021
0411FEFC 00000000 00402821 2C420002 54400006 A2000001 8E020008 00A2102B
54400004 AE050024 A2000001 1000001B 24020001 8E020018 00511021 AE020018
02531021 00511821 0223182B 5460FFEB 00409021 8E020018 00529021 AE120018
02002021 0411FE6E 00000000 54400004 92040002 A2000001 10000008 24020001
2484FFFF 8E030018 00031A42 00831824 00431021 AE020028 00001021 8FBF0024
8FB30020 8FB2001C 8FB10018 8FB00014 03E00008 27BD0028
'pf_read
27BDFFD0 AFBF002C AFB60028 AFB50024 AFB40020 AFB3001C AFB20018 AFB10014
AFB00010 00808021 00A0A821 00E09821 ACE00000 1080004A 24020005 90830001
30630001 10600046 24020004 8C92001C 8C820018 02429023 0246102B 00C2900A
1240003F 00001021 00A0A021 24160200 8E020018 304301FF 5460001F 8E060018
00021A42 92110002 2631FFFF 00718824 323100FF 1620000E 02002021 54400003
8E050024 10000003 8E020020 0411FEA3 00000000 2C430002 50600004 AE020024
A2000001 10000026 24020001 02002021 8E050024 0411FE24 00000000 14400004
00518821 A2000001 1000001D 24020001 AE110028 8E060018 30C601FF 02C61023
0052882B 0251100A 00408821 00002021 0295200B 8E050028 00403821 0411FDC9
00000000 50400004 8E020018 A2000001 1000000B 24020001 00511021 AE020018
02519023 8E620000 00511021 12400003 AE620000 1000FFC6 0291A021 00001021
8FBF002C 8FB60028 8FB50024 8FB40020 8FB3001C 8FB20018 8FB10014 8FB00010
03E00008 27BD0030
'disk_initialize
27BDFFD0 AFBF002C AFB30028 AFB20024 AFB10020 AFB0001C 2403003B 3C02BF80
AC435830 3C029D00 8C430090 8C42001C 80640030 0040F809 24050006 2410000A
0411FD11 00000000 2610FFFF 321000FF 1600FFFB 24040040 00002821 0411FD4F
00000000 24030001 14430061 3C029D00 24040048 240501AA 0411FD48 00000000
24030001 14430037 240400E9 27B00010 27B10014 0411FCFC 00000000 A2020000
26100001 1611FFFB 93A30012 24020001 1462004E 00008021 93A30013 240200AA
1462004B 3C029D00 10000008 24112710 0040F809 24040064 2631FFFF 16200005
240400E9 1000003F 00008021 3C109D00 240400E9 3C054000 0411FD28 00000000
5440FFF3 8E020004 12200038 00008021 2404007A 00002821 0411FD20 00000000
14400033 3C029D00 24110004 0411FCD6 00000000 27A40010 00901821 26100001
1611FFFA A0620000 93B00010 32100040 2402000C 24030004 0070100A 10000023
00408021 00002821 0411FD0C 00000000 2C420002 24030002 24100001 0062800B
240300E9 24130041 0062980B 24112710 10000006 3C129D00 0040F809 24040064
2631FFFF 52200011 00008021 02602021 00002821 0411FCF9 00000000 5440FFF6
8E420004 52200009 00008021 24040050 24050200 0411FCF1 00000000 10000003
0002800B 10000002 3C029D00 3C029D00 8C43008C AC7000FC 8C430090 8C42001C
80640030 0040F809 24050006 0411FC9E 00000000 12000003 24030002 3C02BF80
AC435830 2E020001 8FBF002C 8FB30028 8FB20024 8FB10020 8FB0001C 03E00008
27BD0030
'disk_writep
27BDFFE0 AFBF001C AFB20018 AFB10014 AFB00010 10800014 00808021 30A5FFFF
10A00052 00009021 97828010 1040004F 00858821 92040000 26100001 0411FC8C
00000000 97828010 2442FFFF 3042FFFF 12110045 A7828010 5440FFF7 92040000
10000042 00009021 10A00016 97908010 3C029D00 8C42008C 8C4300FC 30630008
00051240 24040058 0043280A 0411FCB2 00000000 14400035 24120001 240400FF
0411FC73 00000000 240400FE 0411FC70 00000000 24020200 A7828010 1000002B
00009021 26100002 12000008 2610FFFF 2411FFFF 00002021 0411FC65 00000000
2610FFFF 1611FFFC 00002021 0411FC55 00000000 3042001F 24030005 14430010
24120001 10000005 241207D0 0040F809 240403E8 10000003 2652FFFF 241100FF
3C109D00 0411FC47 00000000 50510004 2E520001 5640FFF5 8E020004 24120001
3C029D00 8C430090 8C42001C 80640030 0040F809 24050006 0411FC3A 00000000
10000003 02401021 00009021 02401021 8FBF001C 8FB20018 8FB10014 8FB00010
03E00008 27BD0020
'pf_write
AFB00010 00808021 00C09021 00E09821 ACE00000 1080007B 24020005 90830001
30640001 10800077 24020004 14C00010 30630040 5060000A 92020001 00002021
00002821 0411FF84 00000000 50400004 92020001 A2000001 1000006A 24020001
304200BF A2020001 10000066 00001021 54600006 8E03001C 8E030018 2402FE00
00621024 AE020018 8E03001C 8E020018 00621023 0052182B 14600005 00000000
00A0A021 24150200 10000005 2416FFBF 1440FFFB 00409021 10000053 8FBF002C
8E020018 304301FF 54600029 8E110018 00021A42 92110002 2631FFFF 00718824
323100FF 1620000E 02002021 54400003 8E050024 10000003 8E020020 0411FD32
00000000 2C430002 50600004 AE020024 A2000001 1000003B 24020001 02002021
8E050024 0411FCB3 00000000 14400004 00512821 A2000001 10000032 24020001
AE050028 00002021 0411FF43 00000000 50400004 92020001 A2000001 10000029
24020001 34420040 A2020001 8E110018 323101FF 02B18823 0232102B 0242880A
02802021 02202821 0411FF33 00000000 50400004 8E020018 A2000001 10000019
24020001 00511021 AE020018 8E620000 00511021 AE620000 8E020018 304201FF
5440000D 02519023 00002021 00002821 0411FF21 00000000 50400004 92020001
A2000001 10000007 24020001 00561024 A2020001 02519023 1640FFB1 0291A021
00001021 8FBF002C 8FB60028 8FB50024 8FB40020 8FB3001C 8FB20018 8FB10014
8FB00010 03E00008 27BD0030
'check_fs
27BDFFE0 AFBF001C AFB10018 AFB00014 00808021 00A08821 240601FE 24070002
0411FC20 00000000 14400028 24030003 92040001 00042200 92020000 00822025
7C042620 2402AA55 14820020 24030002 02002021 02202821 24060036 24070002
0411FC10 00000000 1440000A 02002021 92040001 00042200 92020000 00822025
7C042620 24024146 10820010 00001821 02002021 02202821 24060052 24070002
0411FC00 00000000 14400008 24030001 92030001 00031A00 92020000 00621825
7C031E20 38634146 0003182B 00601021 8FBF001C 8FB10018 8FB00014 03E00008
27BD0020
'pf_mount
27BDFFB8 AFBF0044 AFB10040 AFB0003C 00808021 0411FE3B 00000000 30420001
14400087 24030002 27A40010 00002821 0411FFBA 00000000 24030001 1443001A
00008821 27A40010 00002821 240601BE 24070010 0411FBDA 00000000 14400078
24030001 93A20014 10400075 24030006 93B1001B 00118E00 93A2001A 00021400
02228825 93A20018 02228825 93A20019 00021200 02228825 27A40010 02202821
0411FF9E 00000000 24040003 10440064 24030001 14400062 24030006 27A40010
02202821 2406000D 24070024 0411FBBC 00000000 1440005A 24030001 93A2001A
00021200 93A30019 00431025 1440000C 93A30013 93A3002A 00031E00 93A20029
00021400 00621025 93A30027 00431025 93A30028 00031A00 00431025 93A30013
70431002 93A60012 00063200 93A30011 00C33025 02268821 AE11000C 93A50010
A2050002 93A40015 00042200 93A30014 00832025 A6040004 93A30017 00031A00
93A70016 00671825 1460000B 00042102 93A70026 00073E00 93A30025 00031C00
00E31825 93A70023 00671825 93A70024 00073A00 00671825 00661823 00621823
00641823 0065001B 00A001F4 00003012 24C50002 AE050008 24C6F00A 3407EFFF
00C7302B 2CA70FF7 24030002 0066380B 3403FFF7 00A3282B 10A0001F 24030003
10E00017 24030006 24030003 14E3000D A2070000 93A50032 00052E00 93A30031
00031C00 00A32825 93A3002F 00A32825 93A30030 00031A00 00A31825 10000003
AE030010 00511821 AE030010 02248821 02221021 AE020014 A2000001 00001821
00601021 8FBF0044 8FB10040 8FB0003C 03E00008 27BD0048 1000FFE6 A2030000
'pf_open
27BDFFA0 AFBF005C AFB10058 AFB00054 00808821 00A03821 10800025 24100005
A0800001 27A20024 AFA20014 27A50010 27A60030 0411FC99 00000000 1440001C
00408021 93A20030 10400018 93A2003B 30420010 54400016 24100003 02202021
27A50030 0411FBED 00000000 AE220020 93A3004F 00031E00 93A2004E 00021400
00621025 93A3004C 00431025 93A3004D 00031A00 00431025 AE22001C AE200018
24020001 10000002 A2220001 24100003 02001021 8FBF005C 8FB10058 8FB00054
03E00008 27BD0060
'pf_opendir
27BDFFB0 AFBF004C AFB10048 AFB00044 00808021 00A08821 00C03821 10800018
24020005 27A20010 ACA20004 27A6001C 0411FC68 00000000 14400012 8FBF004C
93A2001C 1040000B 02002021 93A30027 30630010 1060000A 24020003 02002021
27A5001C 0411FBBB 00000000 AE220008 02002021 02202821 0411FB5C 00000000
8FBF004C 8FB10048 8FB00044 03E00008 27BD0050
'get_fileinfo
8C830010 10600036 24C20009 90A30000 24040020 1064000E 00A02021 244A0008
24090005 240800E5 10000003 240B0020 106B0007 24840001 00693826 0107180A
A0430000 24420001 544AFFF9 90830001 90A40008 24030020 1083000A 2403002E
A0430000 90A30008 24040020 1464001E 24420001 10000004 90A3000B A0430000
24420001 90A3000B A0C30008 90A4001F 00042600 90A3001E 00031C00 00831825
90A4001C 00641825 90A4001D 00042200 00641825 ACC30000 90A30019 00031A00
90A40018 00641825 A4C30004 90A30017 00031A00 90A40016 00641825 A4C30006
03E00008 A0400000 A0430000 90A30009 24040020 1064FFE3 24420001 A0430000
90A3000A 1464FFDD 24420001 1000FFDE 90A3000B
'dir_read
27BDFFD8 AFBF0024 AFB40020 AFB3001C AFB20018 AFB10014 AFB00010 00809821
00A08021 00C08821 24020003 241200E5 10000019 2414002E 30C6000F 02202021
00063140 24070020 0411FAA9 00000000 0002102B 54400016 AE000010 92230000
50600012 24020003 10720005 9224000B 10740003 30840008 1080000E 8FBF0024
02602021 02002821 0411FB7A 00000000 54400007 AE000010 8E050010 54A0FFE6
96060000 10400003 8FBF0024 AE000010 8FBF0024 8FB40020 8FB3001C 8FB20018
8FB10014 8FB00010 03E00008 27BD0028
'pf_readdir
27BDFFB0 AFBF004C AFB20048 AFB10044 AFB00040 00808821 00A08021 00C09021
1080001B 24020005 27A20010 14C00005 ACA20004 0411FACF 00000000 10000015
8FBF004C 27A6001C 0411FFB9 00000000 24030003 10430004 02002021 1440000D
8FBF004C 02002021 27A5001C 02403021 0411FF6A 00000000 02202021 02002821
0411FB48 00000000 38430003 0003100A 8FBF004C 8FB20048 8FB10044 8FB00040
03E00008 27BD0050
'main
27BDFFB8 AFBF0044 AFBE0040 AFB7003C AFB60038 AFB50034 AFB40030 AFB3002C
AFB20028 AFB10024 AFB00020 00808021 00A0A021 00C0A821 00E0B021 3C02BF80
34038060 AC435800 24030C00 AC435840 24030002 AC435830 3C039D00 8C72008C
26530050 26570078 8C445830 AE440044 8C455800 8C64008C AC850048 8C445840
8C62008C AC44004C 8E020000 144000BE 00008821 3C02BF81 8C44F220 7C84D800
3C030661 3463A053 1083000B 24020050 3C02BF81 8C43F220 7C63D800 3C020660
3442A053 00621026 24030050 2404000C 0082180B 00601021 3C039D00 8C630088
00431021 8C430000 24020065 10620084 3C029D00 8C420010 3C03BF81 8C65F220
7CA5D800 3C030661 3463A053 10A3000B 24040014 3C03BF81 8C64F220 7C84D800
3C030660 3463A053 00832026 24030014 24050003 00A4180B 00602021 24050008
0040F809 00003021 3C029D00 8C420010 3C03BF81 8C65F220 7CA5D800 3C030661
3463A053 10A3000B 24040014 3C03BF81 8C64F220 7C84D800 3C030660 3463A053
00832026 24030014 24050003 00A4180B 00602021 24050064 0040F809 00003021
3C029D00 8C420010 3C03BF81 8C65F220 7CA5D800 3C030661 3463A053 10A3000B
24040029 3C03BF81 8C64F220 7C84D800 3C030660 3463A053 00832026 24030029
2405000E 00A4180B 00602021 24050002 0040F809 00003021 3C029D00 8C420010
3C03BF81 8C65F220 7CA5D800 3C030661 3463A053 10A3000B 24040029 3C03BF81
8C64F220 7C84D800 3C030660 3463A053 00832026 24030029 2405000E 00A4180B
00602021 24050064 0040F809 00003021 3C029D00 8C420010 3C03BF81 8C65F220
7CA5D800 3C030661 3463A053 10A3000B 2404000E 3C03BF81 8C64F220 7C84D800
3C030660 3463A053 00832026 2403000E 24050019 00A4180B 00602021 24050008
3463A053 10A3000B 2404000E 3C03BF81 8C64F220 7C84D800 3C030660 3463A053
00832026 2403000E 24050019 00A4180B 00602021 24050064 0040F809 00003021
3C02BF81 8C43FA84 24040001 7C831804 AC43FA84 3C02BF81 8C43FB04 24040003
7C831804 AC43FB04 3C02BF80 34038060 AC435800 24030C00 AC435840 3C119D00
8E220090 92830000 A0430030 8E230090 8E220010 80640030 24050008 0040F809
00003021 8E230090 8E22001C 80640030 0040F809 24050006 02602021 0411FD8E
00000000 00408821 8E030000 24020001 1462000B 24020002 02802021 0411F91F
00000000 02602021 00402821 0411FE1A 00000000 00408821 8E030000 24020002
5462001E 8E030000 8EA50000 04A00004 02602021 0411FAF9 00000000 00408821
56200016 8E030000 8EC60000 28C20100 10400009 02602021 26850001 27A70010
0411FB4C 00000000 00408821 8FA20010 10000006 A2820000 02802821 27A70010
0411FB44 00000000 00408821 8FA30010 8FA20058 AC430000 8E030000 24020003
5462005B 8E030000 8EBE0000 2411FE00 03D18824 02602021 02202821 0411FAD7
00000000 8EC60000 28C20100 02821021 AFA20018 8EA20000 10510040 3C029D00
8C42003C 0040F809 24040200 0040A821 02602021 00402821 24060200 27A70010
0411FB24 00000000 02602021 02202821 0411FAC2 00000000 1440002A 00408821
33DE01FF 8EC40000 03C42021 2C820201 14400003 00008821 2491FE00 24040200
03C4102A 10400008 8FA20018 02BEF021 02A42021 90430000 A3C30000 27DE0001
17C4FFFC 24420001 02602021 02A02821 8FA60010 27A70010 0411FC5B 00000000
1220000A 02602021 8EC50000 00B12823 8FA20018 00452821 02203021 27A70010
0411FC51 00000000 02602021 00002821 00003021 27A70010 0411FC4B 00000000
00408821 3C029D00 8C420044 0040F809 02A02021 1000000E 8E030000 02602021
8FA50018 27A70010 0411FC3F 00000000 02602021 00002821 00003021 27A70010
0411FC39 00000000 00408821 8E030000 24020004 5462000B 8E030000 02802021
0411F896 00000000 02602021 02E02821 00403021 0411FDC2 00000000 00408821
8E030000 24020005 1462003D 3C029D00 265200A0 02602021 02E02821 02403021
0411FE55 00000000 92440008 24030016 14830007 00408821 02602021 02E02821
02403021 0411FE4C 00000000 00408821 56200028 82430009 8FA20010 02421021
80420009 50400023 82430009 92430008 24020010 50620006 2402003C 24100001
02901821 00001021 1000000C 2405000C A2820001 24020044 A2820002 24020069
A2820003 24020072 A2820004 2402003E A2820005 1000FFF2 24100005 02422021
90840009 A0640001 24420001 1445FFFB 24630001 2402000C AFA20010 26440009
0411F84C 00000000 00501021 A2820000 82430009 2402FFFF 0043880A 3C029D00
8C43008C 8C640044 3C02BF80 AC445830 8C640048 AC445800 8C63004C AC435840
00111FC3 02201021 8FBF0044 8FBE0040 8FB7003C 8FB60038 8FB50034 8FB40030
8FB3002C 8FB20028 8FB10024 8FB00020 03E00008 27BD0048
End CFunction
'CFunction SDcard 'SPI2 version
' 0000062F
' 'rcv_spi
' 240300FF 3C02BF80 AC435A20 3C03BF80 8C625A10 30420080 1040FFFD 3C02BF80
' 8C425A20 03E00008 304200FF
' 'xmit_spi
' 308400FF 3C02BF80 AC445A20 3C03BF80 8C625A10 30420080 1040FFFD 3C02BF80
' 'mem_set
' 10C00006 00801021 00862021 A0450000 24420001 5444FFFE A0450000 03E00008
' 00000000
' 'mem_cmp
' 2407FFFF 24C6FFFF 10C70008 00001021 80830000 80A20000 00621023 14400003
' 24840001 1000FFF7 24A50001 03E00008 00000000
' 'mystrlen
' 80830000 10600006 00001021 24420001 00821821 80630000 5460FFFD 24420001
' 03E00008 00000000
' 'MtoC
' 00801021 80870000 10E0000A 00802821 24830001 00873821 10600004 00000000
' 90660000 A0A60000 24A50001 1467FFFA 24630001 03E00008 A0A00000
' 'send_cmd
' 27BDFFE0 AFBF001C AFB20018 AFB10014 AFB00010 309100FF 7C111420 04410009
' 00A09021 24040077 00002821 0411FFF4 00000000 2C430002 10600034 8FBF001C
' 3231007F 3C109D00 8E030090 8E02001C 80640030 0040F809 24050006 0411FFA3
' 00000000 8E030090 8E02001C 80640030 0040F809 24050005 0411FF9C 00000000
' 02202021 0411FFA4 00000000 00122602 0411FFA1 00000000 7E443C00 0411FF9E
' 00000000 7E443A00 0411FF9B 00000000 324400FF 0411FF98 00000000 24020040
' 12220006 24040095 3A310048 24020001 24030087 00402021 0071200A 0411FF8E
' 00000000 2410000A 0411FF80 00000000 7C021C20 04610004 2610FFFF 321000FF
' 1600FFF9 00000000 8FBF001C 8FB20018 8FB10014 8FB00010 03E00008 27BD0020
' 'disk_readp
' 27BDFFD8 AFBF0024 AFB40020 AFB3001C AFB20018 AFB10014 AFB00010 00809021
' 00C09821 00E0A021 3C029D00 8C42008C 8C4300FC 30630008 00051240 24040051
' 0043280A 0411FFA6 00000000 14400024 24100001 34109C40 241100FF 0411FF5B
' 00000000 14510005 2610FFFF 1600FFFB 00000000 1000001A 24100001 240300FE
' 14430017 24100001 00138823 26310202 12600006 02348823 0411FF4C 00000000
' 2673FFFF 1660FFFC 00000000 02548021 0411FF46 00000000 A2420000 26520001
' 1650FFFB 00000000 0411FF40 00000000 2631FFFF 1620FFFC 00000000 00008021
' 3C029D00 8C430090 8C42001C 80640030 0040F809 24050006 0411FF34 00000000
' 02001021 8FBF0024 8FB40020 8FB3001C 8FB20018 8FB10014 8FB00010 03E00008
' 27BD0028
' 'clust2sect
' 24A5FFFE 8C830008 2463FFFE 00A3182B 10600005 00001021 90830002 8C820014
' 70A32002 00821021 03E00008 00000000
' 'dir_rewind
' 27BDFFE8 AFBF0014 AFB00010 00A08021 A4A00000 8CA50008 24030001 10A30015
' 24020001 8C830008 00A3182B 50600012 8FBF0014 54A00008 AE05000C 90830000
' 24020003 54620008 AE00000C 8C850010 10A00005 AE05000C 0411FFDD 00000000
' 10000003 AE020010 8C820010 AE020010 00001021 8FBF0014 8FB00010 03E00008
' 27BD0018
' 'create_name
' 27BDFFE0 AFBF001C AFB10018 AFB00014 00A08021 8C910004 02202021 24050020
' 2406000B 0411FF09 00000000 8E080000 00002021 00001821 24070008 2409002F
' 2406002E 240A0008 01031021 90420000 24630001 2C450021 14A00018 306300FF
' 50490017 01031821 10460003 0087282B 14A00008 2445FF9F 54EA0011 01031821
' 5446000F 01031821 01402021 1000FFEE 2407000B 30A500FF 2CA5001A 10A00003
' 02242821 2442FFE0 304200FF A0A20000 24840001 1000FFE4 308400FF 01031821
' AE030000 2C420021 A222000B 00001021 8FBF001C 8FB10018 8FB00014 03E00008
' 27BD0020
' 'get_clust
' 90840000 24020003 14820006 00001821 90A30015 00031A00 90A20014 00621825
' 00031C00 90A2001B 00021200 90A4001A 00441025 03E00008 00621025
' 'get_fat
' 27BDFFE0 AFBF001C 2CA20002 1440001B 24030001 8C820008 00A2102B 10400018
' 00601021 000519C2 8C82000C 30A6007F 27A40010 00622821 00063080 24070004
' 0411FF31 00000000 1440000C 24030001 93A30013 00031E00 93A20012 00021400
' 00621825 93A20010 00621825 93A20011 00021200 00621825 7C63D800 00601021
' 8FBF001C 03E00008 27BD0020
' 'dir_next
' 27BDFFE0 AFBF001C AFB20018 AFB10014 AFB00010 00808821 00A08021 94B20000
' 26520001 3252FFFF 12400028 24020003 8CA30010 50600026 8FBF001C 3242000F
' 54400021 A6120000 24630001 ACA30010 8CA5000C 14A00007 00121902 94830004
' 0243182B 14600017 24020003 10000018 8FBF001C 90820002 2442FFFF 00621024
' 54400011 A6120000 0411FFBA 00000000 00402821 2C430002 1460000C 24020001
' 8E230008 00A3182B 10600008 24020003 AE05000C 02202021 0411FF39 00000000
' AE020010 A6120000 00001021 8FBF001C 8FB20018 8FB10014 8FB00010 03E00008
' 27BD0020
' 'dir_find
' 27BDFFD8 AFBF0024 AFB30020 AFB2001C AFB10018 AFB00014 00809821 00A08821
' 00C09021 0411FF31 00000000 14400021 00408021 96260000 30C6000F 02402021
' 8E250010 00063140 24070020 0411FED2 00000000 0002802B 16000017 02001021
' 92420000 50400013 24100003 9242000B 30420008 14400008 02602021 02402021
' 8E250004 2406000B 0411FE55 00000000 10400008 02602021 02202821 0411FF9F
' 00000000 1040FFE3 00408021 10000002 02001021 02001021 8FBF0024 8FB30020
' 8FB2001C 8FB10018 8FB00014 03E00008 27BD0028
' 'follow_path
' 27BDFFE0 AFBF001C AFB20018 AFB10014 AFB00010 00809021 00A08021 AFA7002C
' 80E20000 24030020 14430006 00C08821 24E70001 AFA7002C 80E20000 5043FFFD
' 24E70001 2403002F 54430004 AE000008 24E70001 AFA7002C AE000008 8FA2002C
' 90420000 2C420020 10400008 02002021 02402021 02002821 0411FEE7 00000000
' 1000001B A2200000 02002021 27A5002C 0411FF02 00000000 14400015 02402021
' 02002821 02203021 0411FFA0 00000000 14400010 8FBF001C 8E030004 9063000B
' 5460000D 8FB20018 9222000B 30420010 10400006 02402021 02202821 0411FF28
' 00000000 1000FFE8 AE020008 24020003 8FBF001C 8FB20018 8FB10014 8FB00010
' 03E00008 27BD0020
' 'pf_lseek
' 27BDFFD8 AFBF0024 AFB30020 AFB2001C AFB10018 AFB00014 00808021 1080004F
' 24020005 90830001 30630001 1060004B 24020004 8C82001C 0045902B 00B2100A
' 00409021 8C830018 AC800018 12400043 00001021 90910002 10600012 00118A40
' 2463FFFF 2642FFFF 0051001B 022001F4 00001012 0071001B 022001F4 00002012
' 0044102B 54400008 8E050020 00111023 00431824 AE030018 02439023 10000003
' 8E050024 8E050020 AE050024 0232102B 10400018 00119823 02519023 02002021
' 0411FEFC 00000000 00402821 2C420002 54400006 A2000001 8E020008 00A2102B
' 54400004 AE050024 A2000001 1000001B 24020001 8E020018 00511021 AE020018
' 02531021 00511821 0223182B 5460FFEB 00409021 8E020018 00529021 AE120018
' 02002021 0411FE6E 00000000 54400004 92040002 A2000001 10000008 24020001
' 2484FFFF 8E030018 00031A42 00831824 00431021 AE020028 00001021 8FBF0024
' 8FB30020 8FB2001C 8FB10018 8FB00014 03E00008 27BD0028
' 'pf_read
' 27BDFFD0 AFBF002C AFB60028 AFB50024 AFB40020 AFB3001C AFB20018 AFB10014
' AFB00010 00808021 00A0A821 00E09821 ACE00000 1080004A 24020005 90830001
' 30630001 10600046 24020004 8C92001C 8C820018 02429023 0246102B 00C2900A
' 1240003F 00001021 00A0A021 24160200 8E020018 304301FF 5460001F 8E060018
' 00021A42 92110002 2631FFFF 00718824 323100FF 1620000E 02002021 54400003
' 8E050024 10000003 8E020020 0411FEA3 00000000 2C430002 50600004 AE020024
' A2000001 10000026 24020001 02002021 8E050024 0411FE24 00000000 14400004
' 00518821 A2000001 1000001D 24020001 AE110028 8E060018 30C601FF 02C61023
' 0052882B 0251100A 00408821 00002021 0295200B 8E050028 00403821 0411FDC9
' 00000000 50400004 8E020018 A2000001 1000000B 24020001 00511021 AE020018
' 02519023 8E620000 00511021 12400003 AE620000 1000FFC6 0291A021 00001021
' 8FBF002C 8FB60028 8FB50024 8FB40020 8FB3001C 8FB20018 8FB10014 8FB00010
' 03E00008 27BD0030
' 'disk_initialize
' 27BDFFD0 AFBF002C AFB30028 AFB20024 AFB10020 AFB0001C 2403003B 3C02BF80
' AC435A30 3C029D00 8C430090 8C42001C 80640030 0040F809 24050006 2410000A
' 0411FD11 00000000 2610FFFF 321000FF 1600FFFB 24040040 00002821 0411FD4F
' 00000000 24030001 14430061 3C029D00 24040048 240501AA 0411FD48 00000000
' 24030001 14430037 240400E9 27B00010 27B10014 0411FCFC 00000000 A2020000
' 26100001 1611FFFB 93A30012 24020001 1462004E 00008021 93A30013 240200AA
' 1462004B 3C029D00 10000008 24112710 0040F809 24040064 2631FFFF 16200005
' 240400E9 1000003F 00008021 3C109D00 240400E9 3C054000 0411FD28 00000000
' 5440FFF3 8E020004 12200038 00008021 2404007A 00002821 0411FD20 00000000
' 14400033 3C029D00 24110004 0411FCD6 00000000 27A40010 00901821 26100001
' 1611FFFA A0620000 93B00010 32100040 2402000C 24030004 0070100A 10000023
' 00408021 00002821 0411FD0C 00000000 2C420002 24030002 24100001 0062800B
' 240300E9 24130041 0062980B 24112710 10000006 3C129D00 0040F809 24040064
' 2631FFFF 52200011 00008021 02602021 00002821 0411FCF9 00000000 5440FFF6
' 8E420004 52200009 00008021 24040050 24050200 0411FCF1 00000000 10000003
' 0002800B 10000002 3C029D00 3C029D00 8C43008C AC7000FC 8C430090 8C42001C
' 80640030 0040F809 24050006 0411FC9E 00000000 12000003 24030002 3C02BF80
' AC435A30 2E020001 8FBF002C 8FB30028 8FB20024 8FB10020 8FB0001C 03E00008
' 27BD0030
' 'disk_writep
' 27BDFFE0 AFBF001C AFB20018 AFB10014 AFB00010 10800014 00808021 30A5FFFF
' 10A00052 00009021 97828010 1040004F 00858821 92040000 26100001 0411FC8C
' 00000000 97828010 2442FFFF 3042FFFF 12110045 A7828010 5440FFF7 92040000
' 10000042 00009021 10A00016 97908010 3C029D00 8C42008C 8C4300FC 30630008
' 00051240 24040058 0043280A 0411FCB2 00000000 14400035 24120001 240400FF
' 0411FC73 00000000 240400FE 0411FC70 00000000 24020200 A7828010 1000002B
' 00009021 26100002 12000008 2610FFFF 2411FFFF 00002021 0411FC65 00000000
' 2610FFFF 1611FFFC 00002021 0411FC55 00000000 3042001F 24030005 14430010
' 24120001 10000005 241207D0 0040F809 240403E8 10000003 2652FFFF 241100FF
' 3C109D00 0411FC47 00000000 50510004 2E520001 5640FFF5 8E020004 24120001
' 3C029D00 8C430090 8C42001C 80640030 0040F809 24050006 0411FC3A 00000000
' 10000003 02401021 00009021 02401021 8FBF001C 8FB20018 8FB10014 8FB00010
' 03E00008 27BD0020
' 'pf_write
' AFB00010 00808021 00C09021 00E09821 ACE00000 1080007B 24020005 90830001
' 30640001 10800077 24020004 14C00010 30630040 5060000A 92020001 00002021
' 00002821 0411FF84 00000000 50400004 92020001 A2000001 1000006A 24020001
' 304200BF A2020001 10000066 00001021 54600006 8E03001C 8E030018 2402FE00
' 00621024 AE020018 8E03001C 8E020018 00621023 0052182B 14600005 00000000
' 00A0A021 24150200 10000005 2416FFBF 1440FFFB 00409021 10000053 8FBF002C
' 8E020018 304301FF 54600029 8E110018 00021A42 92110002 2631FFFF 00718824
' 323100FF 1620000E 02002021 54400003 8E050024 10000003 8E020020 0411FD32
' 00000000 2C430002 50600004 AE020024 A2000001 1000003B 24020001 02002021
' 8E050024 0411FCB3 00000000 14400004 00512821 A2000001 10000032 24020001
' AE050028 00002021 0411FF43 00000000 50400004 92020001 A2000001 10000029
' 24020001 34420040 A2020001 8E110018 323101FF 02B18823 0232102B 0242880A
' 02802021 02202821 0411FF33 00000000 50400004 8E020018 A2000001 10000019
' 24020001 00511021 AE020018 8E620000 00511021 AE620000 8E020018 304201FF
' 5440000D 02519023 00002021 00002821 0411FF21 00000000 50400004 92020001
' A2000001 10000007 24020001 00561024 A2020001 02519023 1640FFB1 0291A021
' 00001021 8FBF002C 8FB60028 8FB50024 8FB40020 8FB3001C 8FB20018 8FB10014
' 8FB00010 03E00008 27BD0030
' 'check_fs
' 27BDFFE0 AFBF001C AFB10018 AFB00014 00808021 00A08821 240601FE 24070002
' 0411FC20 00000000 14400028 24030003 92040001 00042200 92020000 00822025
' 7C042620 2402AA55 14820020 24030002 02002021 02202821 24060036 24070002
' 0411FC10 00000000 1440000A 02002021 92040001 00042200 92020000 00822025
' 7C042620 24024146 10820010 00001821 02002021 02202821 24060052 24070002
' 0411FC00 00000000 14400008 24030001 92030001 00031A00 92020000 00621825
' 7C031E20 38634146 0003182B 00601021 8FBF001C 8FB10018 8FB00014 03E00008
' 27BD0020
' 'pf_mount
' 27BDFFB8 AFBF0044 AFB10040 AFB0003C 00808021 0411FE3B 00000000 30420001
' 14400087 24030002 27A40010 00002821 0411FFBA 00000000 24030001 1443001A
' 00008821 27A40010 00002821 240601BE 24070010 0411FBDA 00000000 14400078
' 24030001 93A20014 10400075 24030006 93B1001B 00118E00 93A2001A 00021400
' 02228825 93A20018 02228825 93A20019 00021200 02228825 27A40010 02202821
' 0411FF9E 00000000 24040003 10440064 24030001 14400062 24030006 27A40010
' 02202821 2406000D 24070024 0411FBBC 00000000 1440005A 24030001 93A2001A
' 00021200 93A30019 00431025 1440000C 93A30013 93A3002A 00031E00 93A20029
' 00021400 00621025 93A30027 00431025 93A30028 00031A00 00431025 93A30013
' 70431002 93A60012 00063200 93A30011 00C33025 02268821 AE11000C 93A50010
' A2050002 93A40015 00042200 93A30014 00832025 A6040004 93A30017 00031A00
' 93A70016 00671825 1460000B 00042102 93A70026 00073E00 93A30025 00031C00
' 00E31825 93A70023 00671825 93A70024 00073A00 00671825 00661823 00621823
' 00641823 0065001B 00A001F4 00003012 24C50002 AE050008 24C6F00A 3407EFFF
' 00C7302B 2CA70FF7 24030002 0066380B 3403FFF7 00A3282B 10A0001F 24030003
' 10E00017 24030006 24030003 14E3000D A2070000 93A50032 00052E00 93A30031
' 00031C00 00A32825 93A3002F 00A32825 93A30030 00031A00 00A31825 10000003
' AE030010 00511821 AE030010 02248821 02221021 AE020014 A2000001 00001821
' 00601021 8FBF0044 8FB10040 8FB0003C 03E00008 27BD0048 1000FFE6 A2030000
' 'pf_open
' 27BDFFA0 AFBF005C AFB10058 AFB00054 00808821 00A03821 10800025 24100005
' A0800001 27A20024 AFA20014 27A50010 27A60030 0411FC99 00000000 1440001C
' 00408021 93A20030 10400018 93A2003B 30420010 54400016 24100003 02202021
' 27A50030 0411FBED 00000000 AE220020 93A3004F 00031E00 93A2004E 00021400
' 00621025 93A3004C 00431025 93A3004D 00031A00 00431025 AE22001C AE200018
' 24020001 10000002 A2220001 24100003 02001021 8FBF005C 8FB10058 8FB00054
' 03E00008 27BD0060
' 'pf_opendir
' 27BDFFB0 AFBF004C AFB10048 AFB00044 00808021 00A08821 00C03821 10800018
' 24020005 27A20010 ACA20004 27A6001C 0411FC68 00000000 14400012 8FBF004C
' 93A2001C 1040000B 02002021 93A30027 30630010 1060000A 24020003 02002021
' 27A5001C 0411FBBB 00000000 AE220008 02002021 02202821 0411FB5C 00000000
' 8FBF004C 8FB10048 8FB00044 03E00008 27BD0050
' 'get_fileinfo
' 8C830010 10600036 24C20009 90A30000 24040020 1064000E 00A02021 244A0008
' 24090005 240800E5 10000003 240B0020 106B0007 24840001 00693826 0107180A
' A0430000 24420001 544AFFF9 90830001 90A40008 24030020 1083000A 2403002E
' A0430000 90A30008 24040020 1464001E 24420001 10000004 90A3000B A0430000
' 24420001 90A3000B A0C30008 90A4001F 00042600 90A3001E 00031C00 00831825
' 90A4001C 00641825 90A4001D 00042200 00641825 ACC30000 90A30019 00031A00
' 90A40018 00641825 A4C30004 90A30017 00031A00 90A40016 00641825 A4C30006
' 03E00008 A0400000 A0430000 90A30009 24040020 1064FFE3 24420001 A0430000
' 90A3000A 1464FFDD 24420001 1000FFDE 90A3000B
' 'dir_read
' 27BDFFD8 AFBF0024 AFB40020 AFB3001C AFB20018 AFB10014 AFB00010 00809821
' 00A08021 00C08821 24020003 241200E5 10000019 2414002E 30C6000F 02202021
' 00063140 24070020 0411FAA9 00000000 0002102B 54400016 AE000010 92230000
' 50600012 24020003 10720005 9224000B 10740003 30840008 1080000E 8FBF0024
' 02602021 02002821 0411FB7A 00000000 54400007 AE000010 8E050010 54A0FFE6
' 96060000 10400003 8FBF0024 AE000010 8FBF0024 8FB40020 8FB3001C 8FB20018
' 8FB10014 8FB00010 03E00008 27BD0028
' 'pf_readdir
' 27BDFFB0 AFBF004C AFB20048 AFB10044 AFB00040 00808821 00A08021 00C09021
' 1080001B 24020005 27A20010 14C00005 ACA20004 0411FACF 00000000 10000015
' 8FBF004C 27A6001C 0411FFB9 00000000 24030003 10430004 02002021 1440000D
' 8FBF004C 02002021 27A5001C 02403021 0411FF6A 00000000 02202021 02002821
' 0411FB48 00000000 38430003 0003100A 8FBF004C 8FB20048 8FB10044 8FB00040
' 03E00008 27BD0050
' 'main
' 27BDFFB8 AFBF0044 AFBE0040 AFB7003C AFB60038 AFB50034 AFB40030 AFB3002C
' AFB20028 AFB10024 AFB00020 00808021 00A0A021 00C0A821 00E0B021 3C02BF80
' 34038060 AC435A00 24030C00 AC435A40 24030002 AC435A30 3C029D00 8C52008C
' 26530050 26570078 8C820000 144000BD 00008821 3C02BF81 8C44F220 7C84D800
' 3C030661 3463A053 1083000B 2402002C 3C02BF81 8C43F220 7C63D800 3C020660
' 3442A053 00621026 2403002C 24040060 0082180B 00601021 3C039D00 8C630088
' 00431021 8C430000 24020065 10620084 3C029D00 8C420010 3C03BF81 8C65F220
' 7CA5D800 3C030661 3463A053 10A3000B 2404000B 3C03BF81 8C64F220 7C84D800
' 3C030660 3463A053 00832026 2403000B 24050018 00A4180B 00602021 24050008
' 0040F809 00003021 3C029D00 8C420010 3C03BF81 8C65F220 7CA5D800 3C030661
' 3463A053 10A3000B 2404000B 3C03BF81 8C64F220 7C84D800 3C030660 3463A053
' 00832026 2403000B 24050018 00A4180B 00602021 24050064 0040F809 00003021
' 3C029D00 8C420010 3C03BF81 8C65F220 7CA5D800 3C030661 3463A053 10A3000B
' 24040017 3C03BF81 8C64F220 7C84D800 3C030660 3463A053 00832026 24030017
' 24050006 00A4180B 00602021 24050002 0040F809 00003021 3C029D00 8C420010
' 3C03BF81 8C65F220 7CA5D800 3C030661 3463A053 10A3000B 24040017 3C03BF81
' 8C64F220 7C84D800 3C030660 3463A053 00832026 24030017 24050006 00A4180B
' 00602021 24050064 0040F809 00003021 3C029D00 8C420010 3C03BF81 8C65F220
' 7CA5D800 3C030661 3463A053 10A3000B 2404000F 3C03BF81 8C64F220 7C84D800
' 3C030660 3463A053 00832026 2403000F 2405001A 00A4180B 00602021 24050008
' 3463A053 10A3000B 2404000F 3C03BF81 8C64F220 7C84D800 3C030660 3463A053
' 00832026 2403000F 2405001A 00A4180B 00602021 24050064 0040F809 00003021
' 3C02BF81 8C43FA90 24040004 7C831804 AC43FA90 3C02BF81 8C43FB60 7C831804
' AC43FB60 3C02BF80 34038060 AC435A00 24030C00 AC435A40 3C119D00 8E220090
' 92830000 A0430030 8E230090 8E220010 80640030 24050008 0040F809 00003021
' 8E230090 8E22001C 80640030 0040F809 24050006 02602021 0411FD97 00000000
' 00408821 8E030000 24020001 1462000B 24020002 02802021 0411F928 00000000
' 02602021 00402821 0411FE23 00000000 00408821 8E030000 24020002 5462001E
' 8E030000 8EA50000 04A00004 02602021 0411FB02 00000000 00408821 56200016
' 8E030000 8EC60000 28C20100 10400009 02602021 26850001 27A70010 0411FB55
' 00000000 00408821 8FA20010 10000006 A2820000 02802821 27A70010 0411FB4D
' 00000000 00408821 8FA30010 8FA20058 AC430000 8E030000 24020003 5462005B
' 8E030000 8EBE0000 2411FE00 03D18824 02602021 02202821 0411FAE0 00000000
' 8EC60000 28C20100 02821021 AFA20018 8EA20000 10510040 3C029D00 8C42003C
' 0040F809 24040200 0040A821 02602021 00402821 24060200 27A70010 0411FB2D
' 00000000 02602021 02202821 0411FACB 00000000 1440002A 00408821 33DE01FF
' 8EC40000 03C42021 2C820201 14400003 00008821 2491FE00 24040200 03C4102A
' 10400008 8FA20018 02BEF021 02A42021 90430000 A3C30000 27DE0001 17C4FFFC
' 24420001 02602021 02A02821 8FA60010 27A70010 0411FC64 00000000 1220000A
' 02602021 8EC50000 00B12823 8FA20018 00452821 02203021 27A70010 0411FC5A
' 00000000 02602021 00002821 00003021 27A70010 0411FC54 00000000 00408821
' 3C029D00 8C420044 0040F809 02A02021 1000000E 8E030000 02602021 8FA50018
' 27A70010 0411FC48 00000000 02602021 00002821 00003021 27A70010 0411FC42
' 00000000 00408821 8E030000 24020004 5462000B 8E030000 02802021 0411F89F
' 00000000 02602021 02E02821 00403021 0411FDCB 00000000 00408821 8E030000
' 24020005 1462003D 00111FC3 265200A0 02602021 02E02821 02403021 0411FE5E
' 00000000 92440008 24030016 14830007 00408821 02602021 02E02821 02403021
' 0411FE55 00000000 00408821 56200028 82430009 8FA20010 02421021 80420009
' 50400023 82430009 92430008 24020010 50620006 2402003C 24100001 02901821
' 00001021 1000000C 2405000C A2820001 24020044 A2820002 24020069 A2820003
' 24020072 A2820004 2402003E A2820005 1000FFF2 24100005 02422021 90840009
' A0640001 24420001 1445FFFB 24630001 2402000C AFA20010 26440009 0411F855
' 00000000 00501021 A2820000 82430009 2402FFFF 0043880A 00111FC3 02201021
' 8FBF0044 8FBE0040 8FB7003C 8FB60038 8FB50034 8FB40030 8FB3002C 8FB20028
' 8FB10024 8FB00020 03E00008 27BD0048
'END CFUNCTION
FUNCTION int2Text$(number AS integer)
local num AS integer, outP AS STRING length 60, unit AS INTEGER
local tmpLng1 AS integer
IF 0 = number THEN
int2Text$ = "zero"
EXIT FUNCTION
END IF
num = ABS(number)
DO
tmpLng1 = num MOD 100
SELECT CASE tmpLng1
CASE 1 TO 19
outP = small(tmpLng1) + " " + outP
CASE 20 TO 99
SELECT CASE tmpLng1 MOD 10
CASE 0
outP = tens((tmpLng1 \ 10) - 2) + " " + outP
CASE ELSE
outP = tens((tmpLng1 \ 10) - 2) + "-" + small(tmpLng1 MOD 10) + " " + outP
END SELECT
END SELECT
tmpLng1 = (num MOD 1000) \ 100
IF tmpLng1 THEN
outP = small(tmpLng1) + " hundred " + outP
END IF
num = num \ 1000
IF num < 1 THEN EXIT DO
tmpLng1 = num MOD 1000
IF tmpLng1 THEN outP = big(unit) + " " + outP
unit = unit + 1
LOOP
IF number < 0 THEN outP = "negative " + outP
Do WHILE ASC(RIGHT$(outp,1))<=32
outp = LEFT$(outp,len(outp)-1)
loop
int2Text$ = outP
END FUNCTION
sub prepnumbers
'small
DATA "one", "two", "three", "four", "five", "six", "seven", "eight", "nine", "ten"
DATA "eleven", "twelve", "thirteen", "fourteen", "fifteen", "sixteen", "seventeen", "eighteen", "nineteen"
'tens
DATA "twenty", "thirty", "forty", "fifty", "sixty", "seventy", "eighty", "ninety"
'big
DATA "thousand", "million", "billion"
dim small(19) AS STRING length 10, tens(7) AS STRING length 10, big(2) AS STRING length 10
FOR i = 1 TO 19
READ small(i)
NEXT
FOR i = 0 TO 7
READ tens(i)
NEXT
FOR i = 0 TO 2
READ big(i)
NEXT
end sub
Edited by matherp 2016-04-02
Frank N. Furter
Posted: 09:39am 01 Apr 2016
Thank you very much! This is amazing!!!
Frank
Posted: 02:02am 02 Apr 2016
I've found 1 small bug and a documentation error, I've also fixed a day one feature.
The directory entries were being returned with a leading 0 - this is corrected in the versions below.
Also the documentation for writefile was incorrect - it doesn't return the number of bytes written as these will be the same as the number requested.
Fileopen, whilst working correctly, had previously corrupted the Basic filename - this is now corrected.
ret%=SDcard(writefile,buff$ or buff(),start_byte,#_of_bytes_to_be_written)
New C source
2016-04-02_120113_SDCardV202.zip
SPI 2
CFunction SDcard ' SPI 2 version
0000062F
'rcv_spi
'xmit_spi
'mem_set
00000000
'mem_cmp
'mystrlen
03E00008 00000000
'MtoC
'send_cmd
'disk_readp
27BD0028
'clust2sect
'dir_rewind
27BD0018
'create_name
27BD0020
'get_clust
'get_fat
'dir_next
27BD0020
'dir_find
'follow_path
03E00008 27BD0020
'pf_lseek
'pf_read
03E00008 27BD0030
'disk_initialize
27BD0030
'disk_writep
03E00008 27BD0020
'pf_write
'check_fs
27BD0020
'pf_mount
'pf_open
03E00008 27BD0060
'pf_opendir
'get_fileinfo
'dir_read
'pf_readdir
03E00008 27BD0050
'main
AFB20028 AFB10024 AFB00020 00808821 00A09821 00C0A821 00E0B021 3C02BF80
34038060 AC435A00 24030C00 AC435A40 24030002 AC435A30 3C029D00 8C54008C
26920050 26970078 8C820000 144000BF 00008021 3C02BF81 8C44F220 7C84D800
AC43FB60 3C02BF80 34038060 AC435A00 24030C00 AC435A40 3C109D00 8E020090
92630000 A0430030 8E030090 8E020010 80640030 24050008 0040F809 00003021
8E030090 8E02001C 80640030 0040F809 24050006 8E02008C AC4000F8 02402021
0411FD95 00000000 00408021 8E230000 24020001 1462000B 24020002 82620000
02621021 A0400001 02402021 26650001 0411FE21 00000000 00408021 8E230000
24020002 5462001E 8E230000 8EA50000 04A00004 02402021 0411FB00 00000000
00408021 56000016 8E230000 8EC60000 28C20100 10400009 02402021 26650001
27A70010 0411FB53 00000000 00408021 8FA20010 10000006 A2620000 02602821
27A70010 0411FB4B 00000000 00408021 8FA30010 8FA20058 AC430000 8E230000
24020003 54620067 8E230000 8EA20000 04410005 3C029D00 8C42008C 8C4200F8
AEA20000 3C029D00 8C42008C 8C4400F8 8EC30000 00831821 AC4300F8 8EBE0000
2410FE00 03D08024 02402021 02002821 0411FAD2 00000000 8EC60000 28C20100
02621021 AFA20018 8EA20000 10500040 3C029D00 8C42003C 0040F809 24040200
0040A821 02402021 00402821 24060200 27A70010 0411FB1F 00000000 02402021
02002821 0411FABD 00000000 1440002A 00408021 33DE01FF 8EC40000 03C42021
2C820201 14400003 00008021 2490FE00 24040200 03C4102A 10400008 8FA20018
02BEF021 02A42021 90430000 A3C30000 27DE0001 17C4FFFC 24420001 02402021
02A02821 8FA60010 27A70010 0411FC56 00000000 1200000A 02402021 8EC50000
00B02823 8FA20018 00452821 02003021 27A70010 0411FC4C 00000000 02402021
00002821 00003021 27A70010 0411FC46 00000000 00408021 3C029D00 8C420044
0040F809 02A02021 1000000E 8E230000 02402021 8FA50018 27A70010 0411FC3A
00000000 02402021 00002821 00003021 27A70010 0411FC34 00000000 00408021
8E230000 24020004 5462000B 8E230000 02602021 0411F891 00000000 02402021
02E02821 00403021 0411FDBD 00000000 00408021 8E230000 24020005 1462003E
00101FC3 269400A0 02402021 02E02821 02803021 0411FE50 00000000 92840008
24030016 14830007 00408021 02402021 02E02821 02803021 0411FE47 00000000
00408021 56000029 82830009 8FA20010 02821021 80420009 50400024 82830009
92820008 30420010 54400006 2402003C 24110001 02711821 00001021 1000000C
2405000C A2620001 24020044 A2620002 24020069 A2620003 24020072 A2620004
2402003E A2620005 1000FFF2 24110006 02822021 90840009 A0640000 24420001
1445FFFB 24630001 2402000C AFA20010 26840009 0411F847 00000000 2631FFFF
02228821 A2710000 82830009 2402FFFF 0043800A 00101FC3 02001021 8FBF0044
8FBE0040 8FB7003C 8FB60038 8FB50034 8FB40030 8FB3002C 8FB20028 8FB10024
End CFunction
SPI 1
CFunction SDcard ' SPI 1 version
0000062F
'rcv_spi
'xmit_spi
'mem_set
00000000
'mem_cmp
'mystrlen
03E00008 00000000
'MtoC
'send_cmd
'disk_readp
27BD0028
'clust2sect
'dir_rewind
27BD0018
'create_name
27BD0020
'get_clust
'get_fat
'dir_next
27BD0020
'dir_find
'follow_path
03E00008 27BD0020
'pf_lseek
'pf_read
03E00008 27BD0030
'disk_initialize
27BD0030
'disk_writep
03E00008 27BD0020
'pf_write
'check_fs
27BD0020
'pf_mount
'pf_open
03E00008 27BD0060
'pf_opendir
'get_fileinfo
'dir_read
'pf_readdir
03E00008 27BD0050
'main
AFB20028 AFB10024 AFB00020 00808821 00A0A021 00C0A821 00E0B021 3C02BF80
8C62008C AC44004C 8E220000 144000C0 00008021 3C02BF81 8C44F220 7C84D800
7C831804 AC43FB04 3C02BF80 34038060 AC435800 24030C00 AC435840 3C109D00
8E020090 92830000 A0430030 8E030090 8E020010 80640030 24050008 0040F809
00003021 8E030090 8E02001C 80640030 0040F809 24050006 8E02008C AC4000F8
02602021 0411FD8C 00000000 00408021 8E230000 24020001 1462000B 24020002
82820000 02821021 A0400001 02602021 26850001 0411FE18 00000000 00408021
8E230000 24020002 5462001E 8E230000 8EA50000 04A00004 02602021 0411FAF7
00000000 00408021 56000016 8E230000 8EC60000 28C20100 10400009 02602021
26850001 27A70010 0411FB4A 00000000 00408021 8FA20010 10000006 A2820000
02802821 27A70010 0411FB42 00000000 00408021 8FA30010 8FA20058 AC430000
8E230000 24020003 54620067 8E230000 8EA20000 04410005 3C029D00 8C42008C
8C4200F8 AEA20000 3C029D00 8C42008C 8C4400F8 8EC30000 00831821 AC4300F8
8EBE0000 2410FE00 03D08024 02602021 02002821 0411FAC9 00000000 8EC60000
28C20100 02821021 AFA20018 8EA20000 10500040 3C029D00 8C42003C 0040F809
24040200 0040A821 02602021 00402821 24060200 27A70010 0411FB16 00000000
02602021 02002821 0411FAB4 00000000 1440002A 00408021 33DE01FF 8EC40000
03C42021 2C820201 14400003 00008021 2490FE00 24040200 03C4102A 10400008
8FA20018 02BEF021 02A42021 90430000 A3C30000 27DE0001 17C4FFFC 24420001
02602021 02A02821 8FA60010 27A70010 0411FC4D 00000000 1200000A 02602021
8EC50000 00B02823 8FA20018 00452821 02003021 27A70010 0411FC43 00000000
02602021 00002821 00003021 27A70010 0411FC3D 00000000 00408021 3C029D00
8C420044 0040F809 02A02021 1000000E 8E230000 02602021 8FA50018 27A70010
0411FC31 00000000 02602021 00002821 00003021 27A70010 0411FC2B 00000000
00408021 8E230000 24020004 5462000B 8E230000 02802021 0411F888 00000000
02602021 02E02821 00403021 0411FDB4 00000000 00408021 8E230000 24020005
1462003E 3C029D00 265200A0 02602021 02E02821 02403021 0411FE47 00000000
92440008 24030016 14830007 00408021 02602021 02E02821 02403021 0411FE3E
00000000 00408021 56000029 82430009 8FA20010 02421021 80420009 50400024
82430009 92420008 30420010 54400006 2402003C 24110001 02911821 00001021
1000000C 2405000C A2820001 24020044 A2820002 24020069 A2820003 24020072
A2820004 2402003E A2820005 1000FFF2 24110006 02422021 90840009 A0640000
24420001 1445FFFB 24630001 2402000C AFA20010 26440009 0411F83E 00000000
2631FFFF 02228821 A2910000 82430009 2402FFFF 0043800A 3C029D00 8C43008C
8C640044 3C02BF80 AC445830 8C640048 AC445800 8C63004C AC435840 00101FC3
02001021 8FBF0044 8FBE0040 8FB7003C 8FB60038 8FB50034 8FB40030 8FB3002C
End CFunction
paceman
Posted: 01:24am 03 Apr 2016
Peter, what are the benefits or otherwise of the SPI1 Vs the SPI2 versions? Is it solely that the SPI2 version allows the use of the LCD and touchscreen without specifying CS lines for them, i.e. gaining one extra pin? -- &/or is it that using the SPI1 version frees up the SPI2 pins for other use? -- &/or am I losing the plot a bit?
Greg
Posted: 01:52am 03 Apr 2016
  Quote  what are the benefits or otherwise of the SPI1 Vs the SPI2 versions?
The SPI2 version matches the pins I used on this PCB Edited by matherp 2016-04-04
paceman
Posted: 03:21am 03 Apr 2016
Ahh, - OK, good reason
