Local Time 01:00 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Programming a micromite using a MAC
Posted: 09:08pm 30 Mar 2016
GDay All,
A friend of mine (who I gave a MuP to) has only a MAC laptop.. How can he program his code into his micromite?
I have to admit I am stumped as I do not think that Jim has written a mac version of his (invaluable) MMEdit program
Kind Regards,
jman
Posted: 09:36pm 30 Mar 2016
Hi
This one is not free but does the job
Mac Serial
Jman
ajkw
Posted: 10:43pm 30 Mar 2016
Easy....
Run Terminal
Then issue the command
screen /dev/tty.usbserial-[YOUR-DEVICE-ID] 115200
[YOUR-DEVICE-ID] can be found in System Information / Hardware / USB / Your Device / Serial number when the device is plugged in
Eg DA01IIJ0 for the USB of a MUP 2.
so
screen /dev/tty.usbserial-DA01IIJ0 115200
...Hopefully easy
If you get this far let me know, there was something I did for the F1-F4 keys to work properly also
Anthony
Posted: 10:45pm 30 Mar 2016
On Linux and maybe a Mac you can hit TAB to auto-complete things (command names, files etc), so you can do things like
screen /dev/tty.usb TAB
and it'll fill in the one there is or provide a list if more than one. You just type enough chars to choose from the list and hit TAB again. Have a play...
ajkw
Posted: 11:16pm 30 Mar 2016
TAB is useful
ls /dev/tty TAB TAB
will list them all
so,
screen /dev/tty.usb TAB 115200
will likely bring up your usb device. Note: 115200 is of course the baudrate, use yours accordingly.
As for the function keys,
In the Terminal Menu item choose Preferences / Profiles / Keyboard and edit
F1 Action to \033[11~
F2 Action to \033[12~
F3 Action to \033[13~
F4 Action to \033[14~
and the Function keys should work fine.
Anthony.
Posted: 04:19pm 31 Mar 2016
Thanks Fellas,
OK so I assume a standard USB-TTL Serial adapter will work on his MAC then he can talk to it..
Does he then have to issue the XMODEM commands to send his code or just use the inbuilt editor?
I have been spoilt by MMEdit I am afraid to say...
Kind Regards,
MickEdited by bigmik 2016-04-02
Posted: 04:25pm 31 Mar 2016
XMODEM or AUTOSAVE.
If the Mac program lets you paste code into it and has a sufficient delay between lines being sent, AUTOSAVE is probably the easiest way.
ajkw
Posted: 04:46pm 31 Mar 2016
SCREEN is just a terminal and the inbuilt MM editor works fine.
The MUP LCD Backpack (yours Mick) plugs in fine along with any other the other single board TTL - USB devices I have. They all show up in /dev/tty.usbserialXXXXXX.
I can double check on Xmodem tonight for the Mac however I'm at not-sure to I don't-think-so... Like-wise with pasting
Anthony.Edited by ajkw 2016-04-02
