Local Time 00:51 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 300 baud but 7E2
plasma
Posted: 03:51pm 20 Mar 2016
Hi ,
ive got a industrial dcf modul which sends the data with 300 baud but 7 bit , even Parity and 2 stoppbits.
i need receiving and sending with this , what should i do. ?
gtx
Posted: 06:03pm 20 Mar 2016
Use 8 bit no parity.
For receiving, just mask out the parity bit for each character.
For sending, you will have to generate the parity yourself.
I am sure someone here did that a few months ago.
JTR0701
Posted: 07:03pm 20 Mar 2016
Jim agrees with Jim. Almost if mot all PICs have a 9 bit mode. So 7 for data, 8th bit even parity, 9th bit always set high for first stop bit plus standard stop bit.
Alleged even parity generator for PIC18.
swapf one_byte_cache,W, ACCESS
xorwf one_byte_cache,W, ACCESS
addlw 0x41
iorlw 0x7C
addlw 0x02
bcf one_byte_cache, 7, ACCESS
btfsc WREG,7 , ACCESS
bsf one_byte_cache, 7, ACCESS
