Local Time 00:39 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : TFT ILI9341 resolution
mikedownunder
Posted: 10:42pm 11 Mar 2016
Hi All
Mike again
On the ILI9341 LCD.
Can anybody tell me what does 240RGB x 320 dots mean?
Also How can I work out a location on the LCD?
That's all folks Hope it's not too difficult.
Mike
Posted: 10:57pm 11 Mar 2016
Hi Mike,
The 240x320 is referring to the pixels (dots) that make up the display.
If the TFT screen is 'Portrait' then there are 240 dots/pixels wide, by 320 dots/pixels high.
If in 'landscape' mode, then 320 dots wide, and 240 dots high.
Anything you 'draw' on the screen is given a x & y co-ordinate. The top left hand corner is 0,0.
For Landscape mode, the bottom right corner is 319,239. Note it is not 320,240 as the 'pixel reference coordinate starts at 0; not 1.
For portrait mode the bottom right corner is 239,319.
All text you 'write' to the screen with the TEXT command needs an x & y coordinate. ALSO another 'formatting parameter is given (such as CM) to define exactly where the text is printed.Refer to user manual for full details; but for now just liken it to 'formatting' of text in a word-processor (left, right, centre, top, middle, bottom justified).
All the 'graphical' commands (BOX, CIRCLE, LINE, PIXEL etc) also need a X & Y coordinate.
If you have a TFT connected to a uM then I suggest just working through the various commands detailed in the User Manual (typing them at the command prompt to see the instant result).
Hope this helps a bit.
WWEdited by WhiteWizzard 2016-03-13
Posted: 10:59pm 11 Mar 2016
  Quote  an anybody tell me what does 240RGB x 320 dots mean?
Think of the display as an x-y plot with x scaled from 0-239 and y from 0-319 (in portrait mode) or x scaled from 0-319 and y from 0-239 (in landscape mode)
Lets assume landscape (OPTION LCDPANEL ILI9341,L,....) i.e. 320x240
So to put a single dot in the middle of the screen we could use
PIXEL 160,120
to write a string centred in the screen we could go
TEXT 160,120,"MyString",CM
Hope this makes sense
Posted: 11:07pm 11 Mar 2016
Taking it to the 'next level' there are two 'constants' in MMBasic called MM.HRES and MM.VRES.
When you configure the ILI9341, you have to declare portrait or landscape mode (or the reverse of either).
To position something in the centre of the screen, you can refer to X and Y with numbers, as explained in matherp's post above) OR you could use MM.HRES and MM.VRES.
So with 'any' screen dots size, to position something in the centre of the screen, you would use:
TEXT MM.HRES/2, MM.VRES/2,"MyString",CM
since MM.HRES holds the number of pixels across the width (horizontal), and MM.VRES is the number of pixels high (vertical).
You will see Geoff refers to screen locations using these two inbuilt 'constants' a lot in the User Manual (and other code examples that people post here on TBS).
mikedownunder
Posted: 11:41pm 11 Mar 2016
Hi Guys
Thanks so much for the simple answer and also the prompt replies.
I did understand the MM.HRES & MM.VRES by reading the manual, but couldn't get where the origins were. The answers above make my task so much simpler.
Thanks again
Mike
Posted: 12:05am 12 Mar 2016
Sometimes that resolution is given as 720x320.
Note the missing "RGB" part.
In that case you wil need to divide the first number by three if it is a color screen.
Each pixel is actually made up of three subpixels and some manufacturers use the number of subpixels for resolution. Technically correct as you can address each subpixel, but practical it is not and can be a source of confusion.
